Blog Target to Install 600 Charging Stations at More Than 100 Stores
Discussion in 'Supercharging & Charging Infrastructure' started by TMC Staff, Apr 25, 2018.
  1. Aljohn
    Aljohn Member
    Georgia
    Just for the sake of discussion: Let's suppose retail locations put in 10+ KW chargers capable of 25 miles or more an hour. Just as Tesla came to realize with some urban Super Chargers locations there are a good number of drivers parking for hours to save paying for home charging. At the low rates of 2 mph charge, it becomes a self-regulating charging location. Merely a convenience to add a little charge while shopping and not so enticing that it becomes a substitute for home chargers.
  2. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    #42 cwerdna, Apr 28, 2018
    FWIW, Target in Fremont has them done right because they're not close nor tempting enough to ICE. They've never been ICEd in the times I've been there.
    PlugShare - Find Electric Vehicle Charging Locations Near You
    How To Do Electric-Car Chargers Right: New Target Store In CA
    I don't go there often since it's nowhere near where I live nor work but I have used those EVSEs several times.
    Supercharger - Fremont Hub Shopping Center (LIVE 04-27-2018) is a thread on the location. Perhaps someone there will have a more detailed answer?
  3. ons_
    ons_ Member
    San Mateo, CA
  4. Solar/EV Fan
    Solar/EV Fan Member
    Tucson, Arizona USA
    I prepared a short statement, copies of which I keep in my Tesla, and put them on windshields of ICE vehicles to try to educate the drivers as to why they should not be parking in EV charging slots. I think this is a matter of public education as well as it is of unthinking and selfish actions.
    Also, I think the EV community should be more pro-active in this regard and should try to get EV slots the same protection as handicapped slots with potential tickets and/or towing penalties. We need to push and state and local representatives to make that happen.
  5. Merrill
    Merrill Active Member
    Sonoma, California
    I totally agree, have a copy in my car explaining the charging etiquette. Also until there is a sign saying tow away zone and fine nothing will happen to improve this situation.
  6. YaTravis
    YaTravis New Member
    SLC
    It still helps. Running just a few errands and charging during that time frame replenishes all the battery I use to get around. Every little bit helps...
  7. Lasttoy
    Lasttoy Active Member
    St Augustine, Fl
    I hope someone puts a 220v charger in Charleston SC. I got to I95 with 10 miles left. Could only find one 110v charger.
  8. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    #48 TexasEV, May 2, 2018
    I count about twenty J1772 charging sites in Charleston on Plugshare, and four on the Tesla destination charging map.
    And haven’t you been on this forum long enough to know that the two flavors of electricity are 120V and 240V, not 110 and 220?
  9. RubberToe
    RubberToe Supporting the greater good
    El Lay
    The Target in Pasadena is an ideal location for any company to install EV charging equipment. Easy access off the 210 freeway via Lake Ave exit. Pull right into the top floor of the parking structure, which is essentially empty except for holiday shopping. They use it for storage now. Easy shopping and food access. There is a Total Wine that just opened across the street.
    RT
  10. hill
    hill Active Member
    Lake Forest, CA
    at 208v & 30amps, actually you'd get >6kWh, which would be ~10miles range refreshed. Average stay is 45 minutes (whether costco, home depot, wallmart, or target etc. That'd be 15 miles. So if you life less than 7 miles from the store (like most folks) then you're still ahead.
  11. hill
    hill Active Member
    Lake Forest, CA
    we have property in TN AND CA. Since CA has most of the Teslas (& EV's in general) ... it'd be kind of selfish to want most of 'em to be out in BFE.
    I suspect these HPWC's to be used by all EV's. I know i do. Got me an adapter.
  12. dhanson865
    dhanson865 Active Member
    Knoxville, Tennessee
    I have a hard time thinking of Knoxville as BFE. It's a about 1 million people and a similar number of cars.
    I'm in a dual EV household and I've seen most EV and hybrid types here. I see S and X, Leaf, Bolt and Volt, iMeivs, and such.
    • Disagree x 1
  13. EVie'sDad
    EVie'sDad Member
    Newark, CA
    • Disagree x 1
  14. eprosenx
    eprosenx Active Member
    Beaverton, OR
    For the moment I am going to disagree. I don’t think government regulation is the solution to everything.
    The solution here is actually extremely simple. We are talking about private property here. If a retailer puts up signs with rules that say “you can only park here while charging” then they can just have a towing company enforce the rules. People will learn damned quick.
    EV chargers are an amenity that establishments are putting in to attract clientele who today are above average income. If they want the amenity to be successful they need to police it. They own the property and can make the rules.
    Also though, psychology is a big deal. Optimally EV fast charge spots should be at the back of parking lots so that lazy opportunistic charging people have to work for it. If you *need* a charge to get home you are going to be willing to walk for it.
    The issue is often that electrically it is cheaper to install them up near the store (but not always - sometimes dropping a new meter base at the back of the lot makes sense).
  15. timk225
    timk225 Active Member
    Pittsburgh
    I've been to several HPWC public chargers and some J1772 chargers around my area, and they are almost all 208 volts, And frequently only outputting 180-190 volts, from one leg of a 3 phase input. It'd be better if they were using 240 volt split phase instead.
    And it'd be smart to put charging stations way off on one end of the lot, because us lazy Americans will always park as close to the door as we can, so having the chargers farther away will minimize chances of gas cars being parked there.
  16. eprosenx
    Beaverton, OR
    Yes! Totally agreed! 208v is lame. 240v split phase is better! Drop new transformers at the back of the lot (cheap residential ones!)
    And yes, putting EV chargers in the back also makes a ton of sense for the reason you listed. Keeps folks from using them unless they actually need them!
  17. nwdiver
    nwdiver Well-Known Member
    United States
    208v is actually 2 legs of 3 phase. Same L-G as 240, 120v but 208 is 90 degrees out of phase L-L while 240 is 180 degrees out of phase L-L. 277 is 1 leg of 3 phases and 480v L-L. I wish that was standard for commercial EV charging...
  18. eprosenx
    Beaverton, OR
    Wouldn't L-L on a 3 phase system be 120 degrees out of phase? (not 90 degrees?)
    But yeah, BUMMER that the M3's don't support 277v charging. That is totally the way to go for high speed commercial charging... Less transformation loss!
  19. nwdiver
    United States
    Good catch! You're right 120 degrees. Trig :confused:
  20. Go_Ohm
    Go_Ohm Member
    Durham
    Anyone have updates on the supposed Tesla Supercharger buildout at Target department stores? The Tesla.com Supercharger map has hundreds shown as in process (most coming in 2019), but with the announcement of Electrify America and Target teaming up is this a realignment of allies?
