Tesla door handle failure - pivot gear (anyone have one I can buy?)
Discussion in 'Model S' started by diaretical, Apr 13, 2017.
Tags:
  1. Manzacoty
    Manzacoty Member
    Dallas
    You'll be fine. If it's the rear door you don't need to remove the window. Just watch the videos, take your time and you'll be fine.
    Feel free to post on here if you get into any trouble and one of us can help out.
  2. strider
    strider Active Member
    NE Oklahoma
    Thanks everyone. Repair is completed. 2.5 hours start to finish. It was the driver's door so the window had to come out. Note to @KIKGAZ the interior window seal does need to come out - otherwise there isn't room to pull the window out since the brackets stay on it.
    We did spend a bit of time getting the window alignment correct on the reinstall. I would recommend taking a crayon or something and marking where the seal touches the window before you remove it. That way you can get it aligned again. We had to mess with it for a while to get everything set.
    Otherwise the door handle repair was simple. The Boost Bros' video was great. I also used the Light Harmonic video on remove the interior door panel.
  3. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    The window doesn't have to come out... @Btr_ftw, otherwise know as Car Guru, just posted a video showing his tricks to R&R the handle without taking the window out:
    • Informative x 4
  4. strider
    NE Oklahoma
    Nice find! Didn't think about pulling the trim piece to get to that top bolt.
  5. DC Doc
    DC Doc Member
    Loveland, CO
    Hopefully this DYI is helpful when the rear door handle will not present. It is very common for the white wire on the microswitch to break.
  6. Marc_GA
    Marc_GA Member
    Atlanta, GA
    Well, my rear right is not extending. Called Tesla and 1042845-00-A has been replaced with 1042845-00-B. The newer part (1042845-00-B) is on back-order with over 2000 needed and no ETA.
    Guess I'm going without working doors for a while as the alternative ($750 module replacement) isn't acceptable to me.
  7. Brutaka
    Brutaka Member
    Colorado
    Is this "B" piece supposed to be better? Has anyone proven it to be better? Is it meant for the newer (gen 3) door handles or can it be n the older door handles?
  8. Edo102
    Edo102 Member
    North Carolina
    I can confirm that the B version is a direct replacement. Presumably it was designed to be more durable, but I guess only time will tell.
  9. Naonak
    Naonak Member
    Kansas
    My drivers handle failed this weekend on my P90DL. Taking it in to the service center today.
    Man, what a pain in the ass.
    I wonder if I can convince them to replace all 4 handles with the B version.
  10. Brutaka
    Brutaka Member
    Colorado
    Let us know if you were successful.
  11. Naonak
    Naonak Member
    Kansas
    They said Bs were standard since 2015... so they only replaced the one.
  12. Brutaka
    Brutaka Member
    Colorado
    Makes me wonder if anyone had their Bs replaced and if the cables truly are thicker.
  13. JMG
    JMG Member
    NE Texas
    For what it's worth, mine is an April 2015 build and my driver's side door handle paddle gear failed a few weeks ago.
  14. Brutaka
    Brutaka Member
    Colorado
    Not bad for it being 3 years old.
  15. Naonak
    Naonak Member
    Kansas
    Not bad?? I should think it should NEVER fail. 3 years is kind of ridiculous for a pivot gear in a door.
  16. Barry
    Barry Active Member
    Colorado
    You're a few months behind schedule. My April 2015 went a few months ago.
    Door handle working? It'll break "soon..."
  17. Brutaka
    Brutaka Member
    Colorado
    Well I meant for these cars specifically. But yes that is bad in a broader sense.
  18. jptahiti
    jptahiti New Member
    PAPEETE
  19. jptahiti
    jptahiti New Member
    PAPEETE
    Hi
    Can you tell me how to order this part?
    Looking forward to your answer
    Best regards
  20. jptahiti
    jptahiti New Member
    PAPEETE
