lunitiks
Cool James & Black Teacher
Doesn't the BUC come with HSD-cabling included? Do they actually sell the camera just by itself?
So if I wanted the latest and greatest camera on a pre facelift car, I need all 4 of those parts you listed? And is it plug and play?CABLE, HSD, LIFTGATE, CAMERA 1 (1006780-00-D) $23.12
CABLE, HSD, IP, CAMERA (1006782-00-E) $21.16
BACKUP CAMERA (SEMCO) (1061269-00- 1 C) $78.00
CABLE, HSD, BODY MAIN, CAMERA 1 (1006781-00-E) $25.68
Thanks. Do you know the approximate costs of each of those?
I'm having problems with my front facing camera, and I know one of the cables is bad, so I need one or two new ones.. I just don't know which one(s) yet.
Thanks for your detailed write-up.
I agree -- this is the BEST MOD EVER.. while the lighted applique is awesome, I can't imagine not having the front camera kit.
I didn't know the cables were directional. The problem I'm having is that they front camera feed is intermittent. It worked for a couple of months straight, and then it would just go black. Yesterday I was fiddling with the connector between the camera and the switch box (it's under the frunk trim pieces).. and as I wiggled the connector, the image would cut in and out. So one of those two cables is bad or had some sort of loose connection. I ordered some more contact cleaner (I ran out) to try and remove any corrosion in that connector. If that doesn't work, I need to replace one or both cables.
I've found trolling for parts cars an easy way to pick up the original camera module for a good price.
Oh, and does anyone know how to re-program the front cam kit remote control?
I don't think it's bluetooth, but plain old garage door type RF signal.
I have the remote, with a fresh battery, but it doesn't work.
If you are just replacing the old camera with the new one you only need the camera. (And it is plug and play.) He ordered the extra cables because he is planning to attach a camera to the back of his travel trailer. (You also need extra cables if you are adding a camera to the front of your car.)
Speaking of re-programming the remote. I am trying to create the link to swap views between the front and rear camera using the Homelink button on the center console. I've succeed in the programming, and I see it sending the Homelink signal, but the screens don't swap. Any one with an idea?Oh, and does anyone know how to re-program the front cam kit remote control?
I have the original front cam kit. I had it installed on my '13. BEST MOD EVER. Wonderful. I can't say enough good about Artsci and the crew that made it.
I took delivery on a new '17 90D. I removed the front cam kit from the '13 to install on the '17. However the wiring configurations are different. I have not been able to identify the reverse lead wire so when the car is put in reverse, the console view change to the rear and when in Drive/Park it returns to front cam view. This is frustrating, because we know it works and it worked every time on the '13.
So while trying to locate the correct reverse lead, I hooked up the rest of the front cam kit.
I don't have it connected to the reverse lead, so I use the Bluetooth remote switch to switch between screens. I have missed the front cam view of the splitter and am very pleased to have it back although I have to rely on the BT switch to swap the view. Better than nothing.
I'm sorry that this is slightly off-topic but I want to post it here because I know there are plenty of followers with some camera knowledge.
I have finally gotten around to my trailer camera project. I was able to connect female-female (65") and male-male (144") cables to the existing camera, pull the wires through the liftback access port, and connect them. Doing so makes the existing mounted camera continue to work properly, but gives me access to a long lead that I can use to plug into my camper wiring harness. It currently has a camera, female-female (53"), male-male (144"), and female-female (65") which terminates at the front. When I plug the harness from the X into this length, sadly the camera doesn't work. I'm assuming there's too much loss over the length.
Any ideas on workarounds? I could cut down my length by about 4', but there's no way to do it while maintaining necessary gender. That male cable that only comes in 12' is the part that's troubling me.
One thought was to remove a 144" + 53" section and mount the backup camera high on the roof. However, I really don't want to deal with roof penetrations and I'm not sure how well I'll be able to see with that wide-angle lens anyway.
Thanks in advance..
Did you try it with one of the old-style cameras?
As it turns out, I have a 2014 S.Ohmman, I agree with Hank. I think you should try one of the old camera. Specifically, one from a '13-'14 S. Part Num 1006773-00-E.
I think you are experiencing a problem similar to what I found and described in my post #172. I don't know exactly how to say it, but I believe the signal is weaker with newer camera or cars - don't know which. When I used the old camera (that I purchased in ' Sep '14 for my front cam kit project) on my '17 it worked. The newer camera Part # 1061269-00-B did not work, except with the very short cable <24".
I suggest you either find someone with an older S, and ask them to let you try your new extra camera on their car to validate it works, then ask them to let you keep their camera. (Post your requirement here, and maybe someone would volunteer to take your newer camera and trade permanently with you if it works on their car. Just an idea.)
Or, you should watch for someone parting out a car and buy the old camera. I've heard that they are routinely selling for about $50 used/old car.
So, if i understand correctly about your situation, your newer trailer mounted camera is a newer camera? Its a B or an C?As it turns out, I have a 2014 S.
I'll see if I can't ruin both of my vehicles this evening. Thanks for the feedback.
You understand correctly. The new camera is a C.So, if i understand correctly about your situation, your newer trailer mounted camera is a newer camera? Its a B or an C?
If so, I think you are on to something. I'd connect the new one at your liftgate, and take the one in your liftgate and try it at the lonnnnnng cable to the trailer. Fortunately you can test this by just plugging in the new cam at the liftgate's cable and the longer cable to the liftgates camera without removing anything.
By "just plugging in the new cam at the liftgate's cable" you seem to be either glossing over the removal of all of the liftback trim, or I'm overthinking the project. Is there an easier way to get to that connector?
If you have small hands you can reach in through the left pull down handle that pops out and reach the cable. You also have to be pretty good at disconnecting those Farkar connectors with one hand. But it can be done!
