82k is the Federal limit, 81k was the actual weight during their test run.
Elon talked about the 82k gross weight and the actual 81k during the test run during the presentation.
Diesel engines, transmissions and 300 gallons of fuel weighs a lot as wellBecause batteries weigh a lot. Others posts have said payload 40k to 45k.Tesla didn’t say during the presentation so forces one to assume until they publish specs.
That will be slicker than pig chit for CT
Hell yea, and wouldn’t need the manufacturer on speed dial to make sure everything is ok all the time while having the charge company on speed dial to make sure the chargers are workingCT cannon ball run? It could happen...
35/14*250=625kw at same voltage as current. Moving to 1000V means 2.5*625=1562.V4 verified
Tend to agree.And will require a different plug. It sounds like the new V4 chargers will have the ability to operate at 400V and 1000V so those chargers will instantly become 250/625kw chargers.
I'm sure it is closer to a 1000kWh pack. And the Semi will likely have both a MCS and NACS inlets. There is a reason that they shared V4 Supercharger information tonight.The Semi is different as it's got a rumoured 500kWh pack, and I think as you say will use the new triangular CHARin MW connector, not the NACS/TPS connector.
Dan Priestly (one of the Pepsi guys said thanks Dan and YT and the internet quickly found his LinkedIn profile).This has to be Elon's all-time best new product launch presentation since he didn't talk all that much, leaving it mostly to "the guy on the left" to
The Semi may well also have a NACS outlet but there certainly won't be many supercharger sites where a fully loaded Semi, let alone even the cab can easily charge.
And if when backing up the camera's provide distances on the screen to avoid any depth perception problems?You’re right. My mistake. You said cameras will be the replacement to being able to look out the window when alley docking.
Cameras are not a good replacement for being able to see with your own eyes because again the depth perception is not there
I never saw any rants from Elon. What I did see was Elon responding to relentless rants though.His recent foray into Twitter rants,
If Elon rubbed you the wrong way, oh well. You cannot speak on everyones behalf though.and trying to rub everyone up the wrong way
…and those “Others” claim to have read it “somewhere”. Classic.Others posts have said payload 40k to 45k.
No. That would mean the truck+trailer, and all the chains, etc., weighed 41k lb. (Though it seems a trailer would weigh less than 10k.)A 40k lb payload means the truck would have weighed 41k lbs since Tesla did say the gross weight was 81k lbs.
Elon clearly stated that the CT will use the MW charger.CT likely won’t be able to use MW charger because those are all private currently. And will require a different plug.
The new V4 chargers are the MW chargers. You need to go back review the Semi presentation.It sounds like the new V4 chargers will have the ability to operate at 400V and 1000V so those chargers will instantly become 250/625kw chargers.
