Elon clearly stated that the CT will use the MW charger.
The new V4 chargers are the MW chargers. You need to go back review the Semi presentation.
No, he did not say either one of those things. This is ironic that you are telling other people to review the Semi presentation.
The MW chargers use an entirely different plug type than Superchargers, so what you are saying can't be true. Megachargers are different (in the plug at least) to the V4 Superchargers that are coming. Sure, the cabinet infrastructure running them possibly is the same. But if the Cybertruck only had that triangular Megacharger port, it wouldn't be able to use any Superchargers.
What was said, which is probably what you are thinking of, is that the Semi and Cybertruck will be using that 1,000 V architecture. The new V4 Superchargers may be switchable, so they can charge the passenger cars with the 400V level, but switch to the 1,000V if a Cybertruck plugs in and signals for that. But the V4 Superchargers have to have that NACS plug, not the Megacharger plug, since they are meant primarily for the cars.
The Semi may well also have a NACS outlet
This does seem like a good possibility to me. The Megachargers with the triangular plug are still not going to have many sites, so I don't know if they would risk with that being the only plug type that could recharge it if it ends up too far from "home base" for some reason. I think it would be wise to also have the NACS port so it could use a Supercharger if needed.
