Tesla should increase X75D 0-60 time
Discussion in 'Model X' started by voltaren, May 25, 2017.
Tags:
  1. voltaren
    voltaren Member
    Annapolis, MD
    If the base M3 can do 0-60 in 5.6s, then Tesla should remove the limiter on the X75D to make it quicker. Not necessarily 90 or 100 quick, but drop a half second off at least. OTA update.
    By increase, I mean make the base MX quicker.
    • Love x 3
    • Disagree x 1
  2. zackmilo
    zackmilo 2.2M+ Youtube views on my Model 3
    Los Angeles, CA
    COMPLETELY AGREE! :):):):)
  3. Dutchie
    Dutchie Member
    Canada
    Should do the same with X100D then..
  4. zackmilo
    Los Angeles, CA
    The only thing that is holding them back is that nobody would buy the higher models if they wanted performance they would buy the base. i understand why they aren't but I still want the OTA upgrade.
  5. MXWing
    MXWing Well-Known Member
    HELL YES. I'm all on board this train.
    For daily driving, all I need is 50 miles of range. Let's make all 50 of those miles 0-60 in 3 seconds when coming from a stop.
    • Funny x 2
  6. Halcyon
    Halcyon Member
    CT
    They should unlock it at a modest price and call it 100D Sport or something.
  7. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    I have a 75X and find the accelleration to be just fine. Immediate throttle response makes all the difference in routine driving.
    If you don't get caught up in the printed specs. you will find the standard performance to be more than necessary.
    (and I sold my Viper to get the X)
  8. KidDoc
    KidDoc Supporting Member
    College Station, TX
    I thought it was limited by the inverter as well as battery pack size. As in the inverter has a maximum wh/sec it can put out and the faster builds have a higher maximum. I don't think this is a software throttle.
  9. vigge50
    vigge50 Member
    Sverige
    He 75 kWh batty have lower voltage then the 90 kWh battery wish is the reason for slower acceleration.
  10. MXWing
    Is it realistically difficult to tune these aspects to bring it up?
  11. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    So, by increase, you mean decrease?
    Model X75D curb weight: 5,178lb, 0-60mph: 5.5s
    Model 355 0-60mph: 5.6s ~=> curb weight: ~= 5178 x (5.6/5.5) x (55/75) = 3,866.24
    I think that Tesla won't do that, because physics.
  12. voltaren
    voltaren Member
    Annapolis, MD
    It was confirmed to me that the slower acceleration is a software limitation (by a service advisor in Bethesda). Plus you can clearly feel it. 0-20 is slow compared to 20-60. Brooks from DragTimes also confirmed it. I would agree to the 90 and 100 getting a boost as well.
    Tesla doesn't make slow cars. Why would they have a $100k car accelerate slower than a $35k car? Especially if it is just a marketing ploy utilizing a software limitation. Makes no sense. Elon will come to his senses.
    • Disagree x 1
  13. voltaren
    voltaren Member
    Annapolis, MD
    Has nothing to do with curb weight - you're stuck in ICE physics mode. Plus you're comparing a single motor to a dual motor. It's a software limitation.
    • Disagree x 1
  14. ItsNotAboutTheMoney
    Maine
    Why does the X accelerate more slowly than the S?
  15. travwill
    travwill Active Member
    Chicago, IL
    Long time discssuion on S already. It is a voltage issue for the 70/75 and is limited to not overdraw the available less # cells in those cars. The 90D has 7109 cells to draw power from versus only 5917 cells in 75D.
    The 100D of course has same battery as P100D but in that case it's a physically larger motor in rear.
  16. zackmilo
    Los Angeles, CA
    Tweeted Elon
  17. voltaren
    voltaren Member
    Annapolis, MD
    Software limitation
    • Disagree x 1
  18. zackmilo
    Los Angeles, CA
    Weight also
  19. voltaren
    voltaren Member
    Annapolis, MD
    Then why does the 100 accelerate at the same speed as the 90. I'm a broken record: software limitation.
    • Disagree x 2
  20. zackmilo
    Los Angeles, CA
    IMG_0660.jpg Let's hope for a response!
