Never taken a poly (although I have been with a Polly), but if I were to take one, I'd just turn off my emotion chip...I've taken a poly before (not for clearance). It was very stressful.
Random unfocussed status check:
$35k and Supercharger new are both big pieces of the puzzle. Market hasn't seen them as being so...
It is when it's clearly not true. You don't know what you're talking about or your lying. Either way you need to go.so pointing out that Musk has violated the terms of his security clearance is shitposting?
Good analogy.I’ve seen it described as “the stadium effect”. It’s a phrase I hope becomes household language because it’s a simple analogy people will understand.
As the stadium fills, entry to the stadium slows as it becomes harder for people to take their seats. As the battery fills, charge rate slows as it becomes harder for the charge to find a ‘place to sit’.
Shocked! Ok, not really. I mentioned (2018 Market Action thread) that this would happen. Petro dollars -> congress -> pentagon.Musk security clearance under review by pentagon
The battery packs between the 3 and the Y are going to be the same. It may be possible for the platform to accommodate a larger battery pack, but they will not do this until the Model S can beat the Model 3 in terms of range by a good margin. In other words, the Model 3 and Y will not get a bigger battery pack until after the S & X have bigger battery packs than they have now. Given the size comparisons between the S and the 3, you can pretty much anticipate that the 3 can only have 75% capacity of the S.Question for anyone that might be knowledgeable about this subject. Do you guys think we'll see the introduction of a larger battery pack for Y based on the 2170 cells? Not a big jump or anything but say jump from a 75 battery to an 85(I know the 3 battery is technically larger than 75 but for simplicity sake)? You figure by the time the Y is ready for production, Tesla's cell and pack costs will have gone down even more. What I'm not sure about is if there's room/space to do something like a 85 kw battery pack instead of the 75 one since the Y is based on the 3 platform. Elon said the Y will be about 10% bigger but I would imagine the platform is still the same size as the 3. Given the Y will be less efficient(more weight and higher off the ground), even if they increased the battery pack size by 15-20%, the actual range increase on the top line would only be like 10-15 miles over the 3.
I could also see a larger battery pack introduction for the 3 in 1-1.5 years that takes the top range from 325 to say 350 or 370(the bottom short range gets updated to like 250 range). I feel like now that Tesla has gotten the prices down to where they want.....going forward they can keep prices stable while introducing slight new tech, batteries, etc...Similar to how they continually did S updates for a long time without adjusting the price.
THAT? The market is so irrational.
That's not actually true at all. The main concern with drug use from a security clearance point of view is whether the person lies about it, or could be threatened/bribed/extorted. Clearly none of this applies to Elon.doesnt matter where he did it. people with clearance are not allowed to use drugs - end of story. good thing they finally look into it
