bkp_duke
I didn't realise one could buy insurance for wives ...
Comprehensive auto insurance in the US covers accidents like this one. Sort of wife insurance?
Unless the real constraint is in productionYeah, this one's a total head-scratcher to me... lots of folks would trade if they could keep their FSD; Even more of the early-adopters are hanging on to their old clunkers for free Supercharging and premium connectivity - if they transferred these to new cars too then the S&X sales would go nuts
I don't get it at all
Realistically, a good source for data like this would be scope 3 emissions and raw data.I haven't seen a pic of the Hawthorne Design Center "Supercharger Dashboard" in a while (the one below is from several years ago). You could estimate monthly usage from a heavily used site to get some idea of what it would take to offset with solar + storage.
I think I also saw some stats of overall energy for the whole network somewhere... maybe the annual report?
I don't think we know that. Apparently the EA cabinet holding the power electronics popped and was smoking too. There are also a number of reports of EA stations providing more power, volts/amps, than requested causing vehicles to enter a fail safe mode and cut off charging until some time passes and they are reset. And I have seen one person report that an EA site fried the PCS in their Tesla.
It seems like we have four reports of fried vehicles, each a different brand, but all while charging with EA equipment. That would make me think that the primary fault is on the charger, i.e. EA, side. We know that the power modules in EA sites fail frequently, which is part of why they can't always put out the full power they are rated for, so it could just be a matter that sometimes when they fail they send a surge through to the vehicle.
Here is a Tweet about smoking EA equipment. And here is an article with more details, and includes the report of a Bolt being fried by EA as well. (Who knows how many more instances there have been that just haven't been made public, but it sounds like EA just wanted a paid invoice from the Bolt driver to reimburse him since GM didn't cover it under warranty, which makes me think they know they have problems.)
Any fast charger puts out plenty of current to do serious welding. All that it requires is a short circuit. Sounds to me like it's primarily a fault within the vehicle.
That's exactly what it DID! It FUSED with the cars it was supposed to be charging.If only someone had told them about this brand new concept of "fuses".
Shall I see myself out now?
Wow, you are lucky. We have about 118,000 miles on it and car is from 2017.I have a model S same year with 94k miles.
So far so good. Only extra costs were MCU upgrade and FSD for 5k. But if I had to replace it, I’d get a Y. Especially now with the price reductions and tax breaks. The Y would be cheaper than many comparable gas cars.
What was your old car?
How many miles on your X?
That is what we decided to do. We are away the better part of February, returning in Marvh. Temperature will rise again do we will not need the heater for the time being. First things first and that is to get rid of that stupid tax bill.Keep the car. Keep the stock. Best thing to do is nothing. In five years the car will be worth more than it is today and the stock will 10X.
vehicles should be able to regulate how much current they are taking in
There is a thermocouple in the connectors, but this issue isn't caused by a gradual thing. In the case of the Rivian it happened about a minute after he plugged in. Charging takes ~30 seconds to start. So, nothing had really even started to get warm. It was something that happened instantaneously. (I'm just guessing, but I suspect the EA charger short-circuited, and drew massive current through the connector until a fuse blew.)Installing a thermocouple or infrared sensor in the connector body could detect the encroaching heat even if produced on the vehicle side and then throttle down the charger or turn it off before damage is done.
There is no good reason to avoid designing a charger in this way. It will in no way affect the max charge rate, as the connector should already be designed to accommodate that. It would allow the charger to remain in use once the defective vehicle is removed.
No, they can't. That isn't how DC fast charging works. It works by the car connecting the HV battery directly to the DC pins of the charge port and sending commands to the outboard charger to control voltage/current. All the car can do is monitor it and stop things if the charger sends something beyond what was requested. (But there is a response time involved there, so you can't stop a surge by any means other than a fuse.)
BTW: The cables aren't designed for continuous use at the full capacity. They use the thermocouple to monitor and adjust the maximum allowed at that instant based on how warm it is. (Which is why when the thermocouple fails on EA stalls that they limit it to charging at 34kW, since they have no way to know how hot the cable/connector is.)
Like @MP3Mike wrote, the only direct control the BMS has is to blow the pyro fuse or open the contactors while under (over)load.Well, the BMS should be able to regulate DC fast charging to the extent that if incoming current is in excess of the battery acceptance rate, charging is immediately stopped. But there is definitely a communications problem between the vehicle and charger for that to happen.
Or to send a non negotiable command to the EVSE to cease and desist. Sounds like a communications/design problem. Better integration is obviously needed.Like @MP3Mike wrote, the only direct control the BMS has is to blow the pyro fuse or open the contactors while under (over)load.
The EVSE should not be supplying more current (nor voltage) than requested, and definitely not more current than the connector can handle.
...Or to send a non negotiable command to the EVSE to cease and desist. Sounds like a communications/design problem. Better integration is obviously needed.
Just add support to the Tesla charge cable and implement plug-n-charge while you are at it. Requires some coordination with Tesla, but considering the alternatives probably worth it....
If the EVSE is already not doing what it is supposed to, how are you relying on it to react to an additional command?
I suppose there could be a pure hardware disable signal on a separate pin... However, dropping the pilot signal should already terminate charging.
I predict at some point the X will in fact be a collector’s item along with a few other Model S configs, perhaps early Model 3 employee cars that had a few specials on them.Highly unlikely.
>1Nice picture! Do we know how many cars each ship can carry?
Hmm 17 ships with 2000+ Teslas on each? Solid chance that's more EVs than GM or Ford produced in the entire previous 12 months. On the water floating to their final delivery point. Not counting Teslas on trains, Semi car carriers, or sitting on a lot waiting for the Uber to pick up the customer.Nice picture of the inventory locations for the strong swimmers amongst us:
You wrote "So, CCS required". But what is the force of law, or of regulatory action, or enablement/refusal, of the word "should" in this context?I think further revisions dropped that and specifically call out CCS. (I know the Oregon requirements specifically call out CCS.)
Here is the current federal guidance: https://www.fhwa.dot.gov/environmen...nations/90d_nevi_formula_program_guidance.pdf
So CCS required, and output can't ever be restricted below 150kW for a NEVI compliant port. (Current V2 and V3 Superchargers don't meet either of those requirements.)
On the other hand TravelCenters of America will probably apply for, and get, a bunch of NEVI funding for these installs: TravelCenters of America Enters Agreement with Electrify America to Expand Electric Vehicle Infrastructure (~1,000 chargers at 200 sites.)
