Quite aggressive. So far your post is not insisting lot of confidence that you want to do this (you can't be confident in such a risky market anyway). I believe you have already decided, but in order to succeed you should prevail with the trade long enough. Based on your post, it seems that you are risking more than you can mentally afford. You should work on your backup plan. Have it more detailed. Make some calculations for the 160/140/120$ downside scenario, and look at the numbers. Would you be Ok with that? You should be. Still too much downside risk in the stock price for such uncertain move.
Gambling all on one investment is very dangerous. At least don't invest it all at once. Maybe wait with some significant portion of capital, and after the Q2 production numbers finish the investment, if it still holds true to your investment strategy. You better have a strategy.
Think also about your relationships, possible health issues yours and inside of your family circle(some really unexpected issues) which can put a lot of pressure on your financial situation. All compounded when your investment will go south on you.
Or take some counter measures, which could limit such exposure to external negative factors in play.
When it will turn against you, and you can't stand the pressure any more, and the rationale behind your strategy still holds true, slowly reduce the size of the position one step at a time.
Good luck! And don't forget the regular workout
