OCJeff
You don't have to apply for it. It will just show up as an option for you to sign up.I just got virtual power plant option for my account even though I never applied for it
What I meant is that this has never been there beforeYou don't have to apply for it. It will just show up as an option for you to sign up.
When you click on the VPP does it encourage you to apply or is it fully enabled and showing ~2823 fleet homes and allowing you to set the VPP reserve level?What I meant is that this has never been there before
Can’t tell you. It’s now gone. No longer have this optionWhen you click on the VPP does it encourage you to apply or is it fully enabled and showing ~2823 fleet homes and allowing you to set the VPP reserve level?
So, it sounds like an app glitch since you never signed up in the first place.Can’t tell you. It’s now gone. No longer have this option
Well there are 3 days left and the program requires at least one event a month. No one here has reported any event and there definitely hasn't been one since I joined DSGS on 5/14. Since there isn't a Tesla VPP contact that I could find I did reach out to Olivine that coordinates a lot of this and they said "We are unaware of any test events scheduled by Tesla for the month of May during those dates" (5/1 - 5/15).So, are we going to get a May event for the DSGS program? Supposed to be at least one per month, right?
Who knows at this point. I also don’t know who to contact about the error I’m seeing. Is anyone else seeing this?Well there are 3 days left and the program requires at least one event a month. No one here has reported any event and there definitely hasn't been one since I joined DSGS on 5/14. Since there isn't a Tesla VPP contact that I could find I did reach out to Olivine that coordinates a lot of this and they said "We are unaware of any test events scheduled by Tesla for the month of May during those dates" (5/1 - 5/15).
So we should get one unless Elon laid off the person/team responsible for running the VPP.
Android or Apple IOS? I'm guessing Android as that seems to be flakier than the Apple IOS version. A couple of suggestions in the order of least annoyingI was registered in the original VPP and am now registered in the new program. When I chose from the Tesla App:
Virtual Power Plant -> Settings -> Virtual Power Plant
I receive the following error message (retry does nothing). Does anyone else get this? What should be in this menu setting? VPP is enabled and set to Storm Watch Event Priority. I'm in SCE territory and the VPP screen does show that there are 1814 Fleet Homes
Thanks. I have iOS devices. Happens on both iPad Pro 13” and iPhone 15 Pro Max. Uninstalled and reinstalled. What should be in the sub menu: Virtual Power Plant -> Settings -> Virtual Power Plant?Android or Apple IOS? I'm guessing Android as that seems to be flakier than the Apple IOS version. A couple of suggestions in the order of least annoying
- Restart your phone
- Log out of the app then back in again (I do this often to resurrect the Charge-On-Solar functionality)
- Uninstall and reinstall, will require repairing with your Tesla car if you have one
That is the menu where you can turn on and off the VPP, and also to set the reserve percentage of the VPP event.
Also you can select the storm watch or VPP as the priority event.
Yes, I can turn VPP on/off and set event priority, but when I choose the 2nd VPP option is when I get the error message. Is reserve percentage the only option in that sub menu?
There is no menu on mine. I have the reserve setting slider instead.Can someone please post a screen shot of the menu in Virtual Power Plant -> Settings -> Virtual Power Plant? Of corse, Tesla Chat support is giviing me the run around and telling me not to mess with the app!!! I would like to know what setting is supposed to be presented in that sub menu. I'm on iOS. Thanks!!!
Thanks. Weird. Tesla Chat was of NO help bordering on the side of completely clueless and rude. They said that they would reach out to the app team and get back to me in 10 to 15 business days (typical Tesla level of support). The chat agent's claim was that I was enrolled in the DSDG program and that I should be 'ok'. I suppose I'll just have to wait for the first event to see if that option becomes available. I really don't want to miss out on participation as the previous program worked fine for me. Note, I have PW 2 system at FW version 23.12.11, the agent said that it was the latest ... I thought that there was a newer version of FW for PW2 systems. I'm just grasping at straws to see what the root cause of the problem is.
It seems like there are newer firmware versions based on https://www.netzeroapp.io/firmware_versions, although it's hard to say what their rollout is really like.Thanks. Weird. Tesla Chat was of NO help bordering on the side of completely clueless and rude. They said that they would reach out to the app team and get back to me in 10 to 15 business days (typical Tesla level of support). The chat agent's claim was that I was enrolled in the DSDG program and that I should be 'ok'. I suppose I'll just have to wait for the first event to see if that option becomes available. I really don't want to miss out on participation as the previous program worked fine for me. Note, I have PW 2 system at FW version 23.12.11, the agent said that it was the latest ... I thought that there was a newer version of FW for PW2 systems. I'm just grasping at straws to see what the root cause of the problem is.
I don't think that this is the case. In prior posts @Tim-in-CA has said that he had disenrolled, the app reverted to not being enrolled, enrolled in DSGS, app reported pending and then went fully active.I suspect the issue is that you are registered in both programs (the old ELRP and the new DSGS program), and you're supposed to disenroll from the old one to be able to join the new one. Your app might have not enforced that and as a result got into a bad state.
Here's the link to disenroll from ELRP (this is for SCE, but other CA utilities have similar pages):
There's a possibility of course that disenrolling causes other issues, so proceed at your own risk.
