Has anyone with v9 tried a usb drive with built in wifi, something like this?
https://www.amazon.com/SanDisk-Connect-Wireless-Stick-Flash/dp/B00ZCFYT5K
This way, when you get home and connect to wifi, you could backup the drive over wifi without ever needing to pull the drive. On the home network you could have a service that polls for the usb device to see if it is on the network, and if it is, sync any newer files to a local storage.
I don't even know if I would ever even WANT to do this, but checking to see if anyone else has tried or thought of this.
One downside I assume is that USB port is probably powered off once you leave the car and lock it - so it wouldn't have much time to sync when you leave or return to the house.
