pdx_m3s
Estimated miles at 100% tracks with temperature, so I expect this thread to look a little better come summer time.
I just hooked up ScanMyTesla App and will report later this week on the data I pull.
287 at 100% full charge.
That’s an interesting one. I’ll take your word for it is is not temperature related.
Seems like quite a different look than typical degradation, and at 15%, you are probably less than 1st percentile. Though your mileage is obviously higher than most. Keep us posted.
You are doing a lot better than I am. Charging to 90% daily only nets me 272 miles at 24k miles. Started out at 290 with 4k miles. My 18 LR is screwed.
Would say your chart looks like mine. Yet mine has 20k more in miles. More recent cliff jumping has ensued for both of us.
The green line is the firmware to see if it appears to be related to that
Please note that this is the second Dec-Jan (orange arrows) that this car has gone thru.
I would like to graph down to the 'minor' firmware number after the week-of-the-year ... however, I don't know how to put that in a MSexcel / Gsheets formula for the 5 formats below. If someone wants to take this as a side conversation then I'm more than happy to. I'm currently do the below to fractionalize the week-of-the-year.However, the "minor" firmware revisions aren't taken into account. For all we know they might matter. (In fact, for the 2019.40.50.1 firmware, which is "minor," we know that's when the 2020 Performance vehicles received their "constant" changes based on wheel size.)
It will be a couple months before things get decently warmer there. One test that is being considered is charging to 100% SOC on a weekend day and see via ScanMyTesal and TeslaFI every minute captures when the charging stops. That is not when it gets to 100% but when it continues to 'charge' past that point and does cell balancing. ScanMyTesla does not have module/cell level voltages for TM3s (like the X/S) but you should be able to see the delta between the min and max voltage get smaller as the cell balancing is going on (again ... after you hit 100% and it continues to take amps).To me it does look like there might be some correlation with temperature but I see why you think there is not. In any case, you should be able to remove that from the equation if you have an opportunity to really warm up the battery and then look at the result.
Well I think TeslaFI would pull the data when the charging stopped. So the battery is warmed up form being charged for multiple hours. It is also in a garage. It is only 16 amps but I figured that would still be warming up the battery!I don't know exactly when the TeslaFi pulls its data and what the exact temp of the battery might be at that point.
Assuming you're still at 287.5rmi at 100%, the fullkWh from ScanMyTesla should be about 70.3-70.5kWh for you, as opposed to about 76kWh (or possibly a bit higher) when new.
I'm really very interested in seeing SMT data from someone with a brand new car. I think some videos exist on YouTube showing these new vehicles with higher values than 76kWh (for older model year vehicles) but my current understanding of how things work can't really explain that. 2020 3P vehicles I would expect would show 77-78kWh when new, right now. But would not be surprised if a brand new 2020 3P vehicle showed 79kWh or more.
You are spot on. Nominal remaining is 70.6kWh according to SMT
There is no range mode on the model 3
Thanks. Not spot on though; the middle of my guess window was 0.3% off.Curious - did that end up displaying as 288 @ 100%? It's possible the constant I'm using is very slightly low.
Hopefully the Model 3 battery settles down and maintains that 8% loss.
Busy chart with lots of good info. However, I think you might see more if you focus on just two variables, Rated Range and Temp. Adjust the scales to see more clearly, and see what you get when you just focus on the two, cause I see some correlation with temperature drop.This definitely does not look temperature related. Please note that this is the second Dec-Jan (orange arrows) that this car has gone thru.
The blue estimated 100% number dropped and then dropped more.
The green line is the firmware to see if it appears to be related to that. Look above the 2nd orange arrow and you can see the two major FW updates of 2019.36.* and 2019.40.*.
Thanks! There are really just 2 to focus on.Busy chart with lots of good info. However, I think you might see more if you focus on just two variables, Rated Range and Temp. Adjust the scales to see more clearly, and see what you get when you just focus on the two, cause I see some correlation with temperature drop.
The 3LR has 2% loss in 19,500 miles.
FYI, ABRP log show 72.8 kWh -- Tesla Battery Charging Data from 801 CarsIf you had a CAN bus reader, it would read about 307rmi*234Wh/rmi = 71.8kWh
kWh Wh/mi Range
311.11 = (72.8 * 1000) / 234 = ( kWh*1000 ) / Wh_per_mile
I would argue that you actually have 5.5% capacity loss on this, as the full rated range is 325 miles.
(That being said, the vehicle above didn't appear to receive the "full" unlock - but it probably had significant mileage on it at that point, so hard to say what should have been expected. We know it has the same number of cells as a Dual Motor battery, so it "should" have the same capacity, and the EPA test backs that up.)
You need an adapter to go from a unique one (of several) that Tesla is using to an OBDII. We got one for my sons car and he is using ScanMyTesla to display the data. Most details on the web that I know of are here: Diagnostic Port and Data Access - Tesla Owners OnlineIs the CAN bus on the 3 that would read out the battery capacity accessible from the OBD-2 port, and is the data unencrypted? If so, I may be able to read it with an oscillosope that has serial protocol decoding.
