All three of these items should be addressed now. Near the bottom of the list there will be a "None" selection which will clear out any previously selected icon.
Thanks, that looks (and works) great!
Bruce.
Thanks and I totally understand. I was hoping to replace VT with TeslaFi but I guess I'll have to wait a while for that.I disabled the script for a bit while I rewrite it. It was using quite a bit of server resources while it was converting larger databases like mine which have 350,000+ records. I need to probably break the file into 100,000 record pieces. The other problem is the amount of bandwidth someone could use downloading a file over and over again, mine is currently 150 MB and obviously growing. I'll probably have to put in a quota for 1-2 downloads a month and maybe some of the current months data. I worked on this tonight but didn't get very far. All of the really good export options for the database to export locally, not through a browser.
It only shows up during the window that the car is trying to sleep.Where is the "start polling" button? It said it's in the banner but I see nothing.
Why not all the time?It only shows up during the window that the car is trying to sleep.
It's always polling. The only time is stops polling is you have sleep mode enabled and it pauses polling to allow the car to sleep.Why not all the time?
I do have sleep mode enabled, as I'm trying to get some of the 8-10 miles of vampire loss back. But I'd like to wake up the car and teslafi so it captures a whole trip.It's always polling. The only time is stops polling is you have sleep mode enabled and it pauses polling to allow the car to sleep.
Could you elaborate on the details of Sleep Mode please? I used to have Energy Saver Off and Always Connected On. To try and be better, I turned on scheduled sleep, waited a few days, then turned Energy Saver On (but also left Always Connected On). Regularly now the vehicle takes a good 8+ seconds to boot up the IC, but my 17" lights up and music starts playing before that. So this seems to be more "sleepy" than w/ Energy Saver Off, but TeslaFi says I have 0 minutes of sleep. Is TeslaFi perhaps looking for the CID to go to sleep?
Even if the car is sleeping it still polls the car every minute to see the state (online, offline, asleep, unknown). So if the car is sleeping and you get in to drive it will catch that the state has changed from asleep to online and start polling full data. Usually the time it takes to unlock, get in the car and pull away it's already caught the state change. If you get in really fast and pull away before it catches the state change between the 1 minute polls it will use the last good data it had before it went to sleep as the beginning of your drive.I do have sleep mode enabled, as I'm trying to get some of the 8-10 miles of vampire loss back. But I'd like to wake up the car and teslafi so it captures a whole trip.
All TeslaFi looks for is the battery current to be 0.0 then it will stop polling the car aside from "state" data to give the car time to go to sleep, usually 11 minutes. State returns the following response: online, offline, asleep, unknown - polling this data does not wake up or prevent the car from sleeping.
It looks like TeslaFi tried to let your car sleep 16 times as of 12AM last night but the API never returned that the car is asleep. From what I've read on here people have had to turn always connected to off in order to get the api to return 'asleep' with TeslaFi. It's possible that if you have always connected on it may take the car longer to actually fall asleep(more then the default 15 minutes in settings) but I haven't tried it? I have energy savings on, always connected off and no other sites logging data and usually see between 2-4 miles vampire loss per day depending on how much I'm driving.
Hope that helps some.
My experience is that connected really does need to be off. Even when I set the "time to try sleeping" to 30 minutes, my car never goes to sleep when connected is on. WIth connected off, it happily goes to sleep.Thanks, that is indeed very helpful. Perhaps always connected on/off will change the API return, or the timing is elongated. I will have to see what I can try. I prefer not turning off that option as I do indeed notice my Tesla app loading time change significantly when it is on.
FWIW, I noticed the serious startup lags on 7.1 with energy saver on, even with connected off. This has improved with 8.0. I no longer see any lags even with energy saver on and connected off.
From the testing I had done at start when James was rolling out this feature, it sounds like you started a drive when TeslaFi polling was disabled. I'm very thankful the site sends an email but note that the emails are only sent outside of any scheduled sleep mode you've set. I have mine set from 10pm to 7am so if polling is disabled during that time the site wouldn't tell me. The only workarounds are to minimize/remove scheduled sleep mode OR check the site on your mobile phone to see if the Start Polling button shows in the top header.Is there a limit to the number of drives in a day? Friday evening I went to a party and forgot the wine and double-back on the way there. That trip is noted. On Saturday morning (around 1 am) it noted the return trip. However, I don't see the trip from home to the party. Did I hit a limit for daily drives perhaps? Or did TeslaFi stop polling and not notice the active state on the sleep check?
Your probably right about the missed drive. If the car doesn't actually go to sleep it will keep trying which means it will miss data. I can add another email option to enable notifications during the night. I just have a kid and don't leave the house past 10 so I built it around that. I was also thinking about adding another email address for sleep notifications so you could enter your phone number to get a text when it's trying to sleep. For example if you have Verizon I can email [email protected] to send a text when polling is turned off and sleep mode is trying to let your car sleep.From the testing I had done at start when James was rolling out this feature, it sounds like you started a drive when TeslaFi polling was disabled. I'm very thankful the site sends an email but note that the emails are only sent outside of any scheduled sleep mode you've set. I have mine set from 10pm to 7am so if polling is disabled during that time the site wouldn't tell me. The only workarounds are to minimize/remove scheduled sleep mode OR check the site on your mobile phone to see if the Start Polling button shows in the top header.
