100 packs use different chemistry , newer 75 assumed to have the same chemistry as 100 packs
when did they start to give the 75 the same chemistry as 100 packs?
Pack lifetime kWh used: 4010 kWh
Pack software energy limit: 72.000 kWh (100%)
Pack software type: Energy75
Edit: So.... I just did 85 and 90 pack scatter plots.... and I'm not even sure I should post them. Definitely going to open a can of problem worms for Tesla... ugh.
I would guess around mid June of 2017 when they start producing 75 models with "new drive units" which improves vehicle performancewhen did they start to give the 75 the same chemistry as 100 packs?
Curious, but maybe they had to to fulfill orders already placed. May I ask, did they software lock the battery or did you basically get a free 90 upgrade?Interesting conversation here. I had my 85 battery replaced under warranty and it was showing very little degaradation (maybe 4 miles) over three years. They installed a brand new 90 pack that seems to have been built in September 2017 according to the serial number. Until they replaced my pack I wasn’t even aware they were still making new 90 packs. Should I be worried? Hopefully these new 90 packs have the new chemistry.
I can confirm it shows as a 90 and they rebadged. Range is now about 20 miles more than the 85 had. I’ll be keeping a close eye on degradation over the next year and hope it stabilizes somewhere close to that of the 85
I'm honestly not sure what's best to do about it. I think Tesla hoodwinked everyone here, especially those with the 90-type chemistry.
I have a feeling that, given Tesla's track record thus far on such things, it'll take a big lawsuit to get anything done. All Tesla has done thus far is try to mitigate the issue by dropping current/power limits on charge/discharge and tightening thermal limits (thus lowering overall efficiency) in order to make the issue not as obvious to people.
Yep, the 90 chemistry is garbage. There is no doubt about it. My limited testing at the cell level proved it to me ages ago, but with the data trove bestowed on me a few months ago I can absolutely confirm it.
The supercharge speed issue is the worst, too, because it means an older 85/60 or a newer 100 can supercharge the same range much faster. Even worse is that the BMS for the 90 packs is less tolerant of cell imbalances and will quickly taper charge speed to mitigate a bigger imbalance during a charge.
From what I can tell the 100 pack uses yet another chemistry. The degradation appears to be similar to the original 85s.
Calendar degradation will be tough, because there are a lot of cars with non-original packs. I have the "birthday" for the car, but not the pack. I do have, however, "kWh charged" for every pack... which would be a good axis for a scatter plot (includes regen charging, so probably better overall too). Guess I'll do some later.
@islandbayy What supercharging issues are you seeing? I'm seeing weird rapid tapers within 60 seconds of starting supercharging, tapering down to 90kwh and random capping in the 60kwh range even with less than 30% SOC.
^ That's a whole different can of worms than the capacity issue. Suffice it to say the 90 packs are much more prone to SoC imbalance between cell groups. If one group has over about a 20 mV delta from the pack average, charge speed will taper. The higher the delta, the worse the charge speed reduction.
I swapped out the 90 pack on my S with a newer one because I had two cell groups at something like 40mV delta from the rest of the pack... my top supercharger speed was about 50 kW no matter where I was and it made charging time on my last trip with that pack take 3x as long. The new one is already starting to develop its own uncorrectable imbalance after just ~6000 miles of use.
Suffice it to say... **** the 90 packs.
Why would the imbalance be uncorrectable? Are some cells actually failing?
Failing is the wrong word. More like random, rapid, and extensive degradation (increase in internal resistance) of individual cells causing an uncorrectable imbalance (where the ~100mA bleeder resistors don't have a chance of maintaining balance under normal use).
