Need to find time to summarize some data on the allegedly "dead" horse, but here are my stats:
2013 P85+ 100% range when new - 272 miles. 272 miles x 0.295 kW/mile = 80.24kWh usable, 84.24kWh total including buffer. Where are the missing kWh?
Now, after 4.5+ years and 86,890 miles the 100% range is 253-254 miles (74.6 - 74.9 kWh usable, 78.6 - 78.9kWh total including buffer)
As has been mentioned probably 50 times in this very thread, 100% charge when new means nothing. The BMS isn't even remotely calibrated at that point and it has no idea what the real capacity of the pack is. I guarantee had you attempted to run down to 0% on the very first charge (or even first few cycles) you would have been in for a bad day.
And if we're splitting hairs, even if by some miracle you got one of the best 85 packs ever seen, and somehow your BMS was spot-on from the factory without ever cycling the pack (we'll ignore the fact that this is impossible for the sake of argument).... I still kind of have to point out that you answered your own question: 84.24 is in fact still less than 85.
(Queue a round of rounding up defenses)
When (time of the year) and where (state) was your S85 delivered?Interesting information in this post. Not sure what would be deemed normal or acceptable in degradation / loss of milage capacity. I have S85 and just turned 107,000 miles. I believe the total range charge was 265. I have seen that drop over time and now fully charged I top out at 248 miles / 6.4% degradation.
So, where is the “meaningless” 272 mile number coming from? Is it random?
That does not answer my question. Is it a random number? Why Tesla picked that number?I know it's been mentions here already: Default settings from the factory prior to the system calibrating to actual pack capacity.
Another question is what's required for this number to be re-calibrated to a number you would trust?
It very much does matter. It demonstrates that your story does not add up.
And when this happens, the posts, as usually, descend in rudeness and condescension.
So here are the questions that you do not care to answer so far.
No, there isn't. The diag_vitals data that Tesla logs only reports one capacity value, and I noted that the values I reported were usable energy as reported by the BMS. I suggest you go back and read those posts before making baseless claims.You have fleet wide Tesla data on battery capacity which you quote, but never answer the question **which** of the tesla energy capacity parameters you've used - there is more than one. I have no idea why you chose not to answer this question, but optics of it does not help you case of "stolen" capacity.
No, I fully explained that the number is the result of a pre-calibration value programmed into the BMS at the factory. This will yet again be me saying the same thing. "Hello! Anybody home? Think McFly! Think!" You want to keep hammering at this because it's basically the only thing that would seem to support your position, yet doesn't stand up to any scrutiny whatsoever. You're the one who prefers to harp on it because the truth doesn't fit your story. And just to be clear, I tell no "stories", either. Everything I write is backed up by the facts and the numbers. If I'm speculating, I specifically say so.You dismiss the 272 mile range number, do not believe it has any basis whatsoever, and do not want to answer question or speculate of where this number comes from, because it does not fit your story. You just prefer to dismiss it as Tesla is full of it…
Then there is the story of changing capacity and different numbers of “missing” kWh. Initially it was 4.3kWh (OP in this thread) but now it is 2.38 kWh (85 kWh - 82.62 kWh = 2.38 kWh). You’ve dismissed it as having 2% margin of error for your original claim, but it is 45% reduction in “missing” capacity. You never explained why the difference if original kWh were “proven” by you several different ways, including your own bench testing.
The simple thing is that having initial 100% capacity range of 272 miles, even after multiple deep discharges (or 271, or 273 miles as others noted), is consistent with cases of owners showing that at full SOC Ideal Energy Remaining is between 80 and 81 kWh (i.e. total battery capacity of 84-85 kWh) and is now consistent with EPA data showing that Recharge Event Energy for 85kWh pack was 95.507kWh (battery total efficiency of 81/95.507= 0.85, which is in line, but slightly lower than the battery pack total charging efficiency of 0.88 shown for Model 3: 78.270/89.404=0.88)
There is no “missing” kWh in the 85kWh battery, as multiple data points indicate that usable capacity is 80 – 81kWh, and total capacity including brick protection is 84 – 85kWh. Nothing is missing
I have an S85 with 98k miles and I also top out at 248 miles. It has been +/- 1 since I bought it with 72k miles last year.Interesting information in this post. Not sure what would be deemed normal or acceptable in degradation / loss of milage capacity. I have S85 and just turned 107,000 miles. I believe the total range charge was 265. I have seen that drop over time and now fully charged I top out at 248 miles / 6.4% degradation.
For "90" packs things are even worse. There are about 3500 cars with 90 packs showing < 500 miles with an average usable capacity of 83.2 kWh (or 87.2 kWh total with the 4kWh buffer). Just over 1000 "90" pack cars reporting between 500 and 1000 miles on the odo with an average usable capacity of 82.8 kWh.
Average usable capacity for all ~65k "90" packs in the data: 81.3 kWh with an average odometer of only 11k miles.... that's an average drop from new of almost the same capacity on the 90 pack in 11k miles vs the 85 packs in 37k miles. Pretty crappy.
Yep, the 90 chemistry is garbage. There is no doubt about it. My limited testing at the cell level proved it to me ages ago, but with the data trove bestowed on me a few months ago I can absolutely confirm it.
Edit: So.... I just did 85 and 90 pack scatter plots.... and I'm not even sure I should post them. Definitely going to open a can of problem worms for Tesla... ugh.
FACT: I just drove my car down to 1 mile of range a few weeks ago and then charged to 100% from AC power. This is a newish good condition "90" pack that shows 83 kWh usable (87 kWh total capacity). The recharge event pulled 93.8 kWh from the wall. So, my "90" pack that has ~281 miles of rated RWD range at 100% charge pulls less power from the wall than the EPA calculated for an "85" with, for the sake of argument lets say it showed 272 miles of range. lol. Come on now really?
Good point. The newest variation of the 90 packs has a lot less data than the rest in my database, but the trend seems to be the same as the rest. My guess was the revision isn't cell chem related and instead just other hardware.
The thermal loop is supposedly setup so that the modules are circulated in parallel. In practice, though, it's not completely perfect and some modules get less cooling or heating than others. This is usually fine, but when something like supercharging causes the cooling system to run at full power with no real chance of actually stopping the thermal rise in the cells completely, some deltas do happen. The modules at the front of the pack end up getting more cooling than those at the back, so it's usually an obvious gradient across the pack when looking at the data in larger sets.
I can't say for sure what @islandbayy or @bjornb are seeing with the single module temperature variation can be attributed to the high IR of the 90-type cells during charging, but it's possible. As I said, this only seems to manifest during charging... and I supposed if the cells this is happening to arent evenly distributed and there are more of them in one module, then sure it would cause a temperature spike during charging. You might be able to somewhat confirm this by checking that temperature delta during high discharge... like, run the car pretty hard for a little bit while the temperature is even and see if that same module ends up hotter. Probably not worth the effort, though.
I'm not sure you can count the "as-new" range as reliable. I think at the point the BMS is calibrated and hits the EPA 265 (for a P85), then that is your number set in stone. Not sure how long that calibration takes though, a few full charge/discharge cycles maybe?Need to find time to summarize some data on the allegedly "dead" horse, but here are my stats:
Misc. voltage readings or a "starting point" from Tesla? Unsure. I thought if you took the max capacity an 18650 could have voltage wise and multiply it out by cells then divide by EPA watts / mile, you get that magic 272 number. But still I know less what I'm talking about than most.So, where is the “meaningless” 272 mile number coming from? Is it random?
Please post more data if you can!
Are all 90 packs the same? Same chemistry? No other packs (75 or 100) have been using this chemistry?
My car is about a year old now, after obtaining cable and can-bus interface after a month or two after getting the car I have been following my own pack:
Pack kWh Kilometers Date
83,5 2728 15.feb
83,6 3081 16.feb
83,8 18 may
83,4 10513 15 june
83,4 5 july
83,4 17380 16 oct
83,1 20772 5 Dec
Screenshots, February:
The highest I have seen in May:
In October:
A few days ago (December):
Do you happen to know the layot of the pack and where the temperatures are measured?
Is it two temps per module (coolant temp in and out perhaps?)
This is from my car when it was charging at a SuC last February:
While driving in February:
While driving a few days ago (December):
The highest temp is always measured at position 17...
