OK, what do you believe S85 battery total and usable capacity is?
Yes, you can make that argument. But I think there is still significant difference between Tesla providing a 85kWh (and then it wears down to 82 kWh shortly) vs Tesla providing a pack that was 82kWh from the start.
Yeah, I would take the round numbers with a grain of salt. That is likely just a manufacturer provided number. The test itself only measures usable energy (specifically what is required for car to keep up with drive cycle; so if car enters a limp mode, that part is not counted, even though technically the car can still drive some distance).
I believe that the usable capacity on a "85" Tesla is around 77 or 78kWh.
I'm basing this info on the following (using miles for simplicity)
- The in-car value "VAPI_ratedWattHourPerMile", on a 85D is 290 wh/mi and it's rated range is 270miles. 270 * 290 = 78.3kWh
- Driving around, you'll end up with "estimated range" = "rated range" on the main display when the avg consumption is 290wh/mi. Brand new, my car was showing 271miles rated when full. 271*290 = 78.5kWh
- The in-car value "BMS_nominalFullPackEnergyRemaining" of my car has always been around 77-78. 77.6 right now. Was closer to 78.3 when new. Also unlike the "VAPI_idealEnergyRemaining" value, this one does change with SOC. nominalFullPackEnergy always reports the full, usable pack, calculated by the BMS.
- When driving around with my car, every time I lose 10% of SOC (with 1 decimal point accuracy using the CAN values, not the in-dash values), the trip meter shows ~7.76kWh used. 7.76*10 = 77.6kWh
- I once ran out of juice and had to be towed to the nearest supercharger. The on-board charging screen showed 78kWh was put back into the battery once it hit 100% (took more than 1.5h!) No CAN logs of that one.. and no decimal point accuracy.
- Decided to re-do #5... went a week of commuting without charging then ran in circles around my block until I hit 0% and had the "charge now" message.. Then plugged it in for a full charge Measured the consumption from AC (eGauge with 0.5% certificate using revenue grade CT - this thing also checks voltage) and compared with data on the screen. I'd have to dig the data out, but from memory, apparent charging efficiency was 0.92% (gen 2 chargers) and I pulled around 84-85kWh from the wall (240V@80amps) while the car showed the same 78kWh as on the supercharger.
- I also happen to own a module from a 85 pack (~15000miles care). It's 1/16th of a full battery pack.. and when charging it from 3.11V up to 4.19V (what the car uses as 0 and 100% respectively), my charger calculated 4866Wh. IR was negligible since I was charging at a very low rate (<500W). 4866*16 = 77.85kWh
- Draining the same module with a very accurate 800W resistance, I can run the heater for about 6hours 6 * 800W = 4800. 4800*16 = 76800kWh <-- this value is slightly low because I could not accurately account for the voltage sag of the 800W load and when the load was removed, SOC was slighly above the 0% voltage.. so I guess I could have run it a couple of minutes more.
With all of this in mind I'm pretty sure that 77 or 78 value is solid. Lot of people can do the tests I did with similar results.
For the total capacity, the only thing I can use is my usable capacity plus a static value from the BMS acting as the buffer. In the case of a "85" car, the buffer is reported as 4kWh by the BMS.
Using my 77-78 usable value and adding 4 gives me 81-82kWh total.
If someone can find the low-voltage cutoff used for testing the full capacity (what's the SOC voltage when the buffer is empty), I could do test #7 with my module.
So are we missing 4.something kWh. Probably not. But we're surely missing at least 3kWh.... and I'm not even mentioning that I strongly believe that usable capacity should be advertised... not total. "Hey I just bought this Tesla, it has a 85kWh pack but wait.. but I can only use 78kWh".
That's a good question.Thank you for the detailed reply. I will do the same later today or tomorrow.
Couple more questions, so I really understand where are you coming from. First, what accuracy would you assign to the battery capacity numbers in your post?
Second, what ambient conditions and prior history parameters and to what degree do you think can affect your battery capacity numbers?
Not to beat a dead horse, but my personal observations of my Mx 90D led me to conclude that the usable capacity on my 90D MX is around 78kWh as well.
I havent had a chance to do a non-stop run from 100% at a relatively steady and low highway speed with just me in the car on a somewhat normal outdoor temperature (80F), no rain, no cargo, CC turned off to empty in-order to convince myself that my car indeed has a 90KWH battery. And that is what I was told is how to get the rated miles from the car.
But what are we going to do about it?
So I'd like my 6kwh back now, or the premium I paid to go to 90 from 85 when I ordered....
I'm going off topic right now but it seems the 85-type cell suffer a "huge" drop (2%) in the first 20k miles then it becomes a very shallow curve at around 0.5%/25k miles or something like that (don't quote me on that, pulling that out of my head from memory).
So, once again, @wk057, what exact parameter are you using to state “highest capacity”? There are more than one parameter dealing with capacity.
Apologies for asking the same more than once, but my question was not previously answered.
Also, 78.62kWH average for cars with 500-1000 miles seem to be different than ~77kWh claimed in title of this thread. Could you explain the difference?
Bottom line: Tesla lied about pack capacities. End of story. Do something about it, or get over it. Denying it simply is not an option in the face of the actual data.
As a 90kwh battery owner who saw their "upgraded" capacity rapidly dwindle away in the first couple months, what can we do about this? Or better yet, what would be a reasonable request of Tesla? Personally, that lost capacity means the difference of skipping superchargers on long trips and thereby saving hours potentially. Or not being able to make there-and-back day trips to places where destination charging isn't an option. And wonky supercharging speeds really chaps my bumper. If it comes to light that my randomly capped 45kw-65kw charging speeds are related to something goofy in the 90 packs, that's literally hours I've wasted unnecessarily. I never saw such weird behavior on my 85 pack. So yeah, considering the added cost at purchase, this is a pretty big deal.
Going to jump in on this conversation as well. My 90 pack will be hitting 50,000 miles next week. I'm behind in compiling and posting my videos on my YouTube channel for my range.
I sample my range (And CAN Bus data/Capacity) every 1000 miles. I can honestly say, compared to my old MS60 that was traded in with over 80,000 miles, my 90 pack is absolute garbage in terms of longevity. I've had the car just a hair over 1 1/2 years at this point.
Not to thread crap, but here is the latest that I have up.
My range update videos show the current range, followed by my Compiled data chart since a hour after taking delivery of my car. The Chart is missing some information that I collect now, mainly because I did not have BMS/CAN Bus data back when I got this car.
I've talked with Tesla Service. Reason "Nothing will be done", as they state, is my battery capacity is similar to the rest of the 90's in the Fleet. Well that doesn't say much.
If my 90D was really a 90kWh battery, factoring in usable capacity, so 90-4(reserve)=86kWh usable. My original starting range would be around what, 310?
So here's the deal, original Rated Range 294. Current rated range 1 1/2 years later and less then 50,000 miles is 271. In comparison, a friends 2013 P85 CPO, with about 48,000 miles, original battery, still gets 267 on a 100% charge. And to top it off, no Supercharger Speed Limiting. I'm also limited to 94kW charge rate MAX on superchargers.
So anyways, heres the video with my chart. Video is as of 46k miles. I have the 47, 48, and 49k videos which need editing and the charts compiled. Don't worry, it doesn't get better.
Doesn’t the 100 battery use the same chemistry as the 90? I haven’t seen it reported that the 100’s are experiencing the rapid degradation of the 90’s. Maybe the modified cooling system in the 100s are making them perform better? Or maybe they are going to see the same rapid drop in capacity as the 90s.
My 4 year old S85 with 45k miles has shown only about 3.8% degradation. I’m considering trading for a new 100 - but I’d be unhappy to see heavy early degradation.
@wk057, does your big data dump have information that can be used to determine degradation vs mileage or calendar time? If so, would be interesting to see some scatter plots and fits.
