Why does this battery pack weigh more than the Roadster's? Sounds like they're only using a 3kW charger at the moment.
- The RAV4 EV weighs 3,942 pounds, about 1,000 pounds of which are in the Tesla battery.
- The SUV can go from 0-60 in nine seconds.
- It has an official 100-mile-per-hour top speed (unofficially, test drivers have gotten it to over 103).
- The RAV4 EV has 73 cubic-feet of space, which is exactly the same as the standard RAV4 V6.
- Toyota is claiming a range that varies between 80 and 120 miles from the battery that has 37 kWh of useable energy. The engineers are guaranteeing that the RAV4 EV will beat the Nissan Leaf and its official EPA range of 73 miles. This is nice, but the RAV4 EV is bigger and heavier, an electron-guzzler or sorts, that gets just 2-3 miles per kWh (other EVs get around 4-5 miles), and we assume it will cost a lot more, too. Whatever the official range estimate ends up being, Toyota representatives told us that they will under promise and over deliver.
- The prototype has a Tesla charge port, but the production version will have the standard J1772 connector.
- The demonstration vehicles take ages to charge: 28 hours to fully charge over a standard 110 volt outlet (12 over 240V), but the production version, everyone promised us, will be "significantly improved."
Probably that is just a VERY rough estimate. The Roadster's pack also weighs about 1000lbs, but given the capacity I would expect the RAV4 pack to weigh much less. Otherwise it might be from using lower capacity cells (maybe to save costs). But given Tesla was quoted that the pack has ~4000 cells that seems incorrect too (since it would peg cell capacity at 2600mAh which is higher than in the Roadster). The only other cause I can think of is it might be related to having to mount the packs under the car (so the weight of the shell probably is higher, even though cell weight is lower).Why does this battery pack weigh more than the Roadster's? Sounds like they're only using a 3kW charger at the moment.
...Sheldon Brown, executive program manager for the Toyota Technical Center, said the batteries in the RAV4 EV aren't the same as in the Roadster and are based on a new cell design that is proprietary to Tesla...
Certainly for calendar life. The pack in my RangerEV, and many old Rav4EVs are over 10 years old now, and still working at close to new specs....Proof that NiMH was a good technology...
...the charging connector is Tesla and has an adapter to make it compatible with the J1772 Standard. The production model will have the J1772 plug and connector...
...The battery is liquid cooled with a tight temperature management for cell life and performance in all temperature environments. Similar to the other Tesla vehicles, any time that the car is connected to the charger or whenever the car is turned on, the temperature management system is active. A separate liquid cool loop for the motor and inverter/controller is also planned for the production model, but they are air cooled in these prototypes...
I wouldn't trust the 1000lbs battery quote. The new RAV4-EV is only 220lbs heavier than the V6 version of the RAV4, 582lbs heavier than the 4 cylinder RAV4 (3942lbs vs 3360lbs). Also keep in mind the range numbers for this version will be rated on the newer EPA cycle rather than the old one the original RAV4 EV was rated on.The electric-drive prototype, which weighs in at a healthy 220 pounds more than the gasoline model
"This is nice, but the RAV4 EV is bigger and heavier, an electron-guzzler or sorts, that gets just 2-3 miles per kWh (other EVs get around 4-5 miles)".
What other EV's? ....
Let's see, the Tesla Roadster has a 53 kWh pack... 53 * 4.5= 238.5
The Leaf has a 24 kWh pack... 24 * 4.5 = 108
Sounds like he's in the ballpark to me.
That is a big if - definitely not the official EPA rating. One thing to note is EPA uses the 30% fudge factor after dyno test - not sure whether toyota did.2-3 miles per kWh is pretty typical if that is the EPA rating for the RAV4-EV.
The lithium-ion batteries generate 37 kilowatt-hours, about 50% more than the LIon pack in the smaller, more aerodynamic Nissan Leaf battery-electric vehicle, or BEV. Another key difference is where Nissan has opted for air cooling the battery Tesla engineers chose to go with a more sophisticated – if costly — battery temperature management system, which they believe improves the pack’s performance under a wide range of climate conditions – and increases its life.
