MrBadger
Badger out
I'll have a read through at some point. But some initial thoughts.
Can I suggest that you run the solar figures for your location through PVGIS - it is updated from time to time but looks like the latest version is here JRC Photovoltaic Geographical Information System (PVGIS) - European Commission (europa.eu) - you need to be as exact as you can with orientation, pitch and as much as you can, potential shadows - even slightest shadows.
On a quick skim, I would be wary of the SolarEdge claims. I have had SE for 6+ years so have the data to know how well its works. Its a great system if its needed, but the financial gains may not match what the headlines imply. I actually ended up on the Solar Edge installers list for a while so have a bit of knowledge on how their systems may be pushed.
As for high efficiency panels, they are only of real benefit if you are size limited for standard panels. I went with some high efficiency smaller panels for our setup. My first quote from another company, our roof was size limited (because their panels were very inefficient) and when they came to survey, they were only prepared to put approx 2.6kWp of panels on there - you can only get to close to the edges of the roof. I could have gone for a more standard efficiency panel and got (in those days the max optimal financially) 4kWp on it but I would have had a section of roof full of panels. In the end I went higher efficiency panels, smaller panels but an extra one, and still had loads of roof space.
Also on figures, bear in mind that the bulk of your financial savings will come from the PV. The battery will actually drag down the overall ROI figures.
Easy to work out potential savings on water heater diverters. Look at your summer gas (don't include your standing charge) usage (assuming your dhw is currently gas) for a month and think of 6-7 months of that will be your max saving that would be down to the HW diverter.
And finally, I see you highlighted guarantee. Looks to be only the panels - tbh they should pretty much have an indefinite lifetime. The items likely to fail will be connectors (if incorrectly fitted) and anything that contains electrolytic capacitors, ie the inverter. I ended up extending our SolarEdge warranty (with SolarEdge) from 5(?) to 20 years for a nominal charge.
