Let's clarify some metrics by making a quick benchmark using known stats from the Model S P100D. As can be seen from the table below, the combined torque output of the P100D is
791 lb-ft. This is the peak torque output of the two motors. Using the peak power output of each motor, one can then determine exactly at what RPM each motor provides peak torque (shown in the table). Since they each peak at slightly different RPMs, the net torque is a bit lower than the sum of the two, but they do occur at the same vehicle speed (also shown in the table). Likewise, the combined peak power output is lower than the sum of the two individual outputs, but enough to generate
1.37g of peak acceleration (this calculation agrees well with MT's empirical data) while achieving a 155 MPH top speed.
Now, fast forward (no pun intended) to the new Roadster and we have nearly an order of magnitude leap in the combined motor torque output (
7377 lb-ft vs. 791 lb-ft). This necessitates much taller gear ratios than the P100D's which allows the three motors to spin at much lower RPMs while still producing massive forces at each wheel. I'm running through some preliminary horsepower estimates and will report back shortly, but rest assured the Roadster is a game changer in every way.
