So, OK, someone agrees then.... my thoughts.... it costs more, energy wise, to recharge battery from off-peak (you'll lose 10-15%) than it does to export excess solar and receive FiT. The excess FiT then pays for any off-peak grid usage you use. Hopefully that will be more than you use. Then you save on wear and tear on the battery overnight during off-peak periods and save the capacity for the next morning Shoulder period. Solar will then start recharging the PW during the day. Which is all fine if solar forecast was 100% clear skies. Where it gets tricky is solar forecasting and winter loads.
What I think is a compromise is to set the reserve to the percentage remaining at 10pm (end of shoulder period M-F). The house uses grid at off-peak rates overnight. Then at 6:45am the next morning, set reserve to 0% so by 7am (start of shoulder) low solar production, the battery will service the house until solar production exceeds house consumption. Solar continues to service house and PW until the PW is 100%. The rest will be exported to grid. Keep house on self-powered mode to 10pm (covering Peak and shoulder periods). The pattern repeats to Friday. Then Friday night, set reserve to 100% and house is on grid for off-peak rates all weekend + solar. Any excess solar is exported. PW2 will be 100% charged by Monday 7am. And the cycle repeats....
Now, the tricky bit is getting the price differential between FiT and off-peak rates to work out which is the best way to go (taking into account energy/costs loss of 10-15% when recharging vs export). Recharge from grid to top up battery overnight at off-peak rates or reserve the battery overnight for next day's Peak/Shoulder periods until solar recharges for nothing. Hmmm..... my brain hurts now.... too many variables and scenarios with energy and costs calculations and which one maximises the best return!
