beeeerock
Looks like the 'official' cable organizer (support) that would be used where the red piece is below.If I may ask, what is the black device on the wall above the HPWC?
Thanks,
Bruce.
Thanks,
Bruce.
Thanks,
Bruce.
Can you elaborate? We are building a house over the next year and I'll need to instruct our electrician if the plug needs to be upside down in order to hang correctly. Can this be added to FlasherZ's FAQ? Thanks!Another tip is that some electricians will put the outlet in upside down for our application.
You want the ground pin on top, and they will put it in with the ground pin on the bottom.
Not to get hung up on details, but I've often wondered why even a 110 volt receptacle has the ground on the bottom. If the plug is inadvertently pulled part way out and something conductive falls across it, I'd think it's better that it contact the ground pin than the hot! More so with 240 volts and big amps...! But perhaps there's different logic I haven't considered, beside "it just looks better"?There is no standard for receptacle orientation, and electricians generally do it whichever way they've been taught or whatever theory they've adopted. Most 5-15 receptacles get installed ground-down, although some electricians wire them ground-up (my home has them ground-down, the ones in my shop were installed ground-up). In some cases, this "ground down" orientation gets associated to 14-50 receptacles too. The good news is that the occurrence of this is pretty rare - most of the range, dryer, and RV cords place the ground pin on top, and the plugs you buy in the supply shop have ground pin up, so most electricians know better. But occasionally you'll get the guy who doesn't know any better.
It's a good point, and I added it to the FAQ.
Our bathroom has the plugs like this and it drives my wife nuts - her hair dryer has a circuit breaker "brick" on the end of the cord and it has to be plugged in upside down. As she's drying her her the weight of the cord pulls it out of the wall. I think the "something falling on the hot pins and shorting" is a old wive's tale. Maybe in the old days when fuses blew slower than breakers but then we didn't have grounded outlets at all back then. Today's breakers trip very fast so the chance of an accident are low.Not to get hung up on details, but I've often wondered why even a 110 volt receptacle has the ground on the bottom. If the plug is inadvertently pulled part way out and something conductive falls across it, I'd think it's better that it contact the ground pin than the hot! More so with 240 volts and big amps...! But perhaps there's different logic I haven't considered, beside "it just looks better"?
LOL... you should see the blackened wall socket in my elderly father's basement shop... I don't know what he dropped onto the partially exposed prongs, but it made a bit of a mess. Recent house build, modern breakers... He admitted to the prongs being exposed but not much else!I think the "something falling on the hot pins and shorting" is a old wive's tale. Maybe in the old days when fuses blew slower than breakers but then we didn't have grounded outlets at all back then. Today's breakers trip very fast so the chance of an accident are low.
Well, I just learned something new! After 50 years of living with those sockets all around me, I've never realized that they're ALL upside down! That's actually pretty funny... :biggrin:I think the "standard" is to install so that the writing text on the socket is written "right side up"...
So I think "ground on top" is the "standard" for everything, but most homes are installed with their 5-15s upside down...
But the problem is that most cheap 5-15 sockets don't have any labeling on the front so people forget which way to orient them! :tongue:
That argument is made frequently (and it's usually the cited reason why someone prefers ground-up). I have indeed dropped a metal faceplate across the hot and neutral blades of an outlet before, but the occurrence of that is very rare and doesn't make up for the hundreds of devices that have plugs expecting ground-down. Bottom line is that it's installer preference...Not to get hung up on details, but I've often wondered why even a 110 volt receptacle has the ground on the bottom. If the plug is inadvertently pulled part way out and something conductive falls across it, I'd think it's better that it contact the ground pin than the hot! More so with 240 volts and big amps...! But perhaps there's different logic I haven't considered, beside "it just looks better"?
