Thank you for the great advice. Could we say how frequently should one be checking the tire pressure?
So, this is one of those questions that gets answered, first, as, "It Depends."
Let's say one doesn't have excessively leaky tires. Keep the temperature the same and the tires will lose, say, about 1 psi a month. Which, in theory, if one is trying to stay around 42 psi, one would only need to check and adjust the pressure once every month or two.
But then one runs into Physics. The standard pressure equation from good old high school chemistry, is
PV = n*R*T
Where P is pressure, V is the volume, n is the number of moles, R is a fudge factor, and T is a temperature on an absolute temperature scale. Like, for example, Kelvin. Or Rankine, which is the Fahrenheit equivalent. Let's stick with Kelvin for the moment.
If we're looking at Pressure, volume is fixed, let's say that "n" is fixed, R
is fixed, and T is in Kelvin.
Room temperature = 25C; Kelvin is 273 plus that = 25+273 = 298K
Let's say the temperature drops to freezing. that's 0C, or 273K.
What does the pressure do?
P = n*R*T/V, but Delta-P = n*R*delta-T/V
And, yeah, this actually works, even with PSI being in pounds per square inch.
So, let's say that P = 45 psi. Then, n*R/V = P/T, so we got n*R/V = 45/298 = 0.151.
So, Delta-P = 0.151*(Delta-T). If we got Delta-T = (273-298) = -25, then the Pressure difference is a-gonna be 0.151*(-25) = -3.77 psi. So, instead of being at 45 psi, one will be at about 41.
So, if one is old-school and doesn't have TPMS (describing me and VW Beetles back in 1971), one checks the air pressure about every other week. Because air leaks. Because temperature changes. Etc. Bicycle tires are the same way, only, with typically higher pressures at 65 to 90 psi, they naturally leak more, so drop off more rapidly.
But! You're Driving A Tesla! Reach up the Ye Screen and, just below the image of the car, there's a little panel that (typically) has one's streaming service or radio station on it. Swipe to the left twice - and there's your tire pressures. Alternatively, hit the bottom left corner "car" symbol and tap the Service menu. And there's your tire pressures!
Check it once a week or so. If it's low, go fill your tires up. If it's high (happens when the temperatures zoom from freezing to the 70's, or 70's to the 90's), go let some air out of your tires.
If you're going on a long trip, check your tire pressures, just like you check that you got snacks and drinks in the back.
Tesla's certainly don't need much maintenance, but tire pressures is one of those that drivers should do and don't need a service station employee
to do.
