Got some @MountainPass goodies to install this weekend. Also going to give the DIY alignment another shot, got an idea on how to make sure toe is the same on both sides.
@destructure00,
“Christmas in March” !!!
Ski
Of course we NEED our FIX.....photos of all that eye candy installed!
Ski
We are levelling up our packaging game! We didn't plan ahead for the cyber arms though so now we need more boxes!Why are you getting fancy boxes?All mine came in generic brown boxes.
We should have an option at checkout to use vague shipping information and plain boxes for this reasonI will gladly take the generic boxes over the fancy boxes if it means I'm in the initial batch. Plus, generic boxes do not raise the suspicion of my better half.![]()
Lowering the car will increase the rear camber, but not much, will do next to zero in the front. Economical way would be do the front camber arm and rear camber arm. Rear toe arm is nice to have, makes toe adjustment easy compare to the stock eccentric bolt.
I should add if I only get the camber arms and keep it stock height, I shouldn't need the toe arms right?
Yes. When you add negative camber (as you would for the track) toe goes out, and vice versa.I just want at least 2 degree of front and rear camber as that is a reasonable enough compromise that I won’t destroy my tires (it’s wife’s daily driver). If I move the camber, does the toe change?
Having some fun today. Hopefully will get the rear alignment all set this afternoon and do front arms tomorrow.
I had the alignment down to 1/32" toe in each side (.16deg total) measured from brake rotor to string. Then decided to play with camber. Set it back and went to check again but the car shifted a bit on the blocks, so now I gotta restring the car to see if it's still good.
@MountainPass my 6 year old daughter sends her thanks for the candy in the toe arm box
View attachment 519183 View attachment 519184
More eye candy / suspension Bling? I can't see you without these for long!
