Two down. Lunch/beer break soon then alignment time.
I see you are running the full stack.
Gotta start somewhere! Lmao. I wanted to get parts installed first then start tweaking alignment.
Just checked front and have camber 0.9 FL 1.0 FR, .08 deg total toe. Instead of dialing in stockish alignment this afternoon maybe I'll start playing a little bit. Just because @beastmode13 is giving me crap
I'm going to take the advice given here and set and forget the rear. Will adjust front between track and street with shims and tie rod turns.
How do these look for targets? It's a combination of specs that a few of you have posted earlier in this thread.
Rear - full time:
-2.2 camber
.16 toe in total
Front - street w/ 8mm shim:
-2.2 camber
.08 toe in total
Front - track w/ no shim:
-3.5 camber
0 toe
Not sure how exact I'll be able to get the front camber, will just have to see where I land with the shims.
There you go. Washer isn’t required. MPP is doing mid cycle HW updates a la the Tesla way.Current MPP instructions don't have washers in the parts list. I wonder if they decided they weren't necessary sometime recentlView attachment 519546
Rear - full time:
-2.2 camber
.16 toe in total
-2.2 camber
.08 toe in total
-3.5 camber
0 toe
Also, I'll note that I didn't install the included fender liner bolts and haven't had issues so far. But your mileage may vary depending on your suspension setup.View attachment 519639
So I currently have 6mm shims installed and only seeing 1.6/1.7 camber in front. Per MPP guide I should be seeing around 2.2. Seems off by quite a bit...is this within the normal variance range?
I suspect that those numbers assume you have a coilover kit set to their recommended ride height. If you have stock ride height on the other hand that presumably accounts for the difference in negative camber. At least that's my best guess.
Height does not change the front camber, only change the rear.
