This is a great idea; I have a HPWC laying around and now I know exactly what to use it for, thank you!
OP; I would check out my sticky thread for a good synopsis to answer your questions.
However, the most important things you will want to do is wheels, tires, brakes, and fixing the nonexistent camber. Wheels and tires are all personal preference, there is a giant thread on here discussing that. I'm running 18's with 265's (previously had 275's). As far as brake pads are concerned, IMO the best option right now is the one's from Carbotech. They are a long lasting dedicated track pad for a reasonable price. If you want something a bit more street-oriented see RB. For Camber, MPP is your one-stop-shop. The Front Upper Control Arm's and Rear Upper Camber Arms will solve that issue. Everything else is just icing on the cake really.
FWIW, I have set my fast laps at ~65% SOC, I don't really notice a time-affecting drop off until under about 60% SOC, then it falls offer rather quickly. Doesn't mean you can't still have fun though!
P.S. Track Mode is amazing. I had an F80 M3 before this and "MDM" was completely useless. Cut power constantly. The only way to drive that car was with TC fully disabled. Track Mode does not pose these issues, I really love it.
Why did you switch from 275 to 265? Rubbing?
I am installing camber + coilovers+ rear arms here soonish on 18x9.5, +34 wheels and wondering if I can fit 275 after lowering about 1"
275 front is no problem with extra camber, but with the stock arms we ended up chopping a tire on the fender. Sasha does like to smash curbs but it is definitely just a bit too much tire without the FUCA's.@mcbarnet007 275 fit fine with camber, right?
Right, I should have clarified - with extra camber all around via camber arms, especially up front. I know it's being done, but since I'm on 265s, I figured it would be best to hear firsthand from the guy setting blazing laps at Buttonwillow on that size tire.
Now you mentioned it, I did chop a 275 tire on the fender on stock arm once at Laguna Seca at turn 11. But it was a rare instance and running 275 on stock arm at Buttonwillow Raceway was not a problem. I would consider rolling the fender a tiny little bit as stock fender has some area that sticks out.
In my opinion the Model 3 is an excellent daily car that you can take to the track but I wouldn't buy one as a track car. I think a better option would be a used EVO or STI built to be on the track and have a Tesla as the daily. That said I'll probably do about 4 track days a year with my Model 3 Performance because I can't afford it and a dedicated track car. The biggest down side is charging I get about 3 sessions before the power loss starts being noticable and bothering me. I try to charge at lunch between sessions to make the most of my day. But you miss out on being able to hang out with friends and talk cars and end up eating a sandwich by yourself at the supercharger. The pads, wheels/ tires and camber can be fixed with aftermarket so it's not a concern. It's a very capable car on the track but also pretty expensive to be beating on at the track.
As far as warranty goes you have to realize that the car is capable of reporting to Tesla pretty much at any time and has at least 8 cameras and GPS built in. When you have a warranty issue the techs often "remote in" to the car and check the driving logs. I don't think it will be to hard to see that the car was being driven on a track if they wanted to look that deep into it. Per the warranty any damage caused racing and tracking the car will not be covered. I've had my car in for warranty and they didn't mention anything about my track shenanigans but I wouldn't be surprised if they knew about it though.
This is my experience as well. If you can have room for multiple cars, get a SR+ and a 20k track car. If you can only have one car, P3D plus all of MPP's modification for occasional track day is not a bad idea.
Another thing you can do is fine Tesla track day buddies so they can go to SC with you after every session.
Another thing you can do is find Tesla track day buddies so they can go to SC with you after every session.
The tires I wanted were not available in a 275. That being said, the difference in grip between a 265 and a 275 is negligible. 275's do definitely fit.
Everything was fine, but there is a certain steering angle + curb strike that can cause it to touch. Better to let people know because ruining tires sucks!
I think Tesla is mostly pretty cool with letting us track the car and not being too strict on denying warranty claims, though they certainly could if they wanted. Last time i took my car to the service center a guy ran out (who worked there) and said he saw me at the track the previous weekend. They actually ended up giving me goodwill/warranty to fix an interior noise, so that was nice and they probably could've flat out said "no you track it" instead.
I have the same dilemma. I have a 370z that I use at the track. It's fun and I have had it for 10 years. If I get a performance, I have to sell it. If I get a base or AWD, I can keep it but then I probably have no reason to buy a 3 if I am going to leave it outside. I might as well keep my Volt or get a Bolt. I am leaning toward performance because of garage space. I simply don't have the garage space and having a car that I only use for 2-3 track days a year absolutely sucks. While the car won't depreciate much anymore, but it's a pain to have the car in the garage. The battery is always dead, I have to work around the car in the garage as I don't want to cold start it. If I charge my car, I have to move my X out in the middle of the night so I can charge them at off peak hours. It's a hassle. At this point, I am ready to throw in the towel and move on. It also doesn't help I have a clutch and diff job coming, the expenses will probably rise by 3-4K. Maybe it is time for a fresh start. Also driving a gas car is like smoking at this point. Once you are used to not smelling it, it's hard to go back.
I currently have a non tesla EV because the track car is taking up the garage space...
A dedicated garage is $250K, trust me I looked into it.....
Oh to add to the sadness, I have 8 slicks on rims in my garage, 4 spares for my Model X
