Hey all -
I have a Model X with the towing package and it's giving me some trouble.
I have a little 4x8 utility trailer that I use once in a while to run for some lumber or whatever, but for the third time now, after going for a drive with it connected, trailer mode won't shut off when I disconnect the trailer. I can manually disable it but the yellow light stays on and must be re-disabled every time I get in.
The previous two times this has happened, I took it in for service and they replaced the rear body control module. The second time it happened they claim to have done a thorough checking of other wiring to make sure there was no other issue but they found nothing. They advised I check out my trailer to make sure there are no wiring issues on it.
So since then I've honestly been avoiding using the trailer as I haven't wanted to risk it. Tonight, though, I checked over the trailer wiring and replaced the 4-pin connector as it had been damaged since the last time I used it. Other than that it's basically a brand new trailer and wiring. I hooked it up and tested everything and it was working fine. I connected and disconnected it and trailer mode behaved as expected. So I then took it out for a 5-minute drive and of course, upon returning, trailer mode stayed on after I disconnected the trailer.
I'm feeling rather frustrated at this point. Even if there is a problem with my trailer somewhere that I haven't found, it seems like a mighty big design flaw that it could cause this control module to malfunction as it has. This is a simple trailer with basic tail lights, blinkers, etc. only, so worst case scenario would be a short somewhere, right? Shouldn't that be protected by a fuse at the very least?
At this point I'm not looking forward to dealing with getting it back for service (though it's due for regular maintenance so at least it won't be an extra trip). Anybody have any thoughts?
