My soft top did leak just a bit at the top front corner of the driver's side window.
There is a little triangular flap of rubber that is part of the drain on the A pillar at the top front corner of the window. When you install the soft top you need to make sure to flip that triangle outward so that it is on top of the horizontal rubber on the soft-top side member, otherwise you will get a leak at that spot.
