Long shot/tinfoil hat theory but could Elon be planning to use this to fund a merger/take private?
Bloomberg - Are you a robot?
Nah, SpaceX needs that to build their Starlink constellation and launch it in time to meet the FCC requirements.
25k RWD the last week?
am i reading that correctly?
lemurs?
Yes, and with the actual trading price of the notes and interest rates, there won't be any damages to show.To save those the trouble, the case is based on the argument that "Tesla is liable because its production ramp is six months behind."
Well, I don't think they are going to build Y in Fremont, at least not only in Fremont. They're not going to build 10k/week+ in Fremont. I think they need another NA GF for Y+Pickup at minimum, possibly two if they can't do some production at Fremont. Those GF's will get their own cell lines with enough capacity to feed them. GF1 only has to feed Fremont (3, S/X after switch to 2170, anything else that gets built there) and GF1 (TE, anything else that gets built there).
Building the pickup on S/X line is a bad choice, at least without a major overhaul to the S/X platform (which arguably they're due for anyways), and even then I don't think there's really a good argument for sharing S/X/pickup. Just because other makes share SUV and truck lines doesn't mean you can easily build a truck on the S/X platform. Certainly if they did share a platform, S/X should switch to 2170 before or at the same time, not be running a mix - and then your argument to make a paltry tends of thousands of high priced trucks to take up slack in the production capacity (due to cell supply) would be solved by just building more S/X anyways.
What I'd like to see is that GF3 (China) and GF4 (Europe) move ahead on their own schedules, financed through local debt (like China), first doing GA of Model 3 and possibly Tilburg style assembly for S/X, and planning ahead to have the cell capacity lined up not only to bring up 3 production but also Y production at each location.
Separately, in parallel, I'd like to see construction for GF5 and possibly GF6 (if Fremont/GF1 can't handle the added production) somewhere in North America, someplace where housing workers isn't such a problem - perhaps targeting someplace where some existing manufacturers will be failing so that it's easy to pick up labor. GF5/6 should be georaphically spread apart - perhaps one in the rust belt, the other in the south. These will produce Y and pickup to start with, perhaps Semi. These may have to be built from cash (rather than debt) unlike GF3/4, so likely have to start one at a time. I would get Panasonic to install 1-2 lines ASAP and start with making TE cells and growing TE output. Once almost ready to start Y and/or pickup production, switch one or more cell lines to vehicle chemistry for a short while (perhaps a week or two?), then switch back to TE. This brief output will be enough to do initial start of ramping, and once you get close to needing a whole cell line's output, switch it over to vehicle output again, and have Panasonic install another pair of lines. The new lines may not even go to TE initially, depending on timing, may already have switched to pure vehicle output from the cell lines and need more.
Ideally, Panasonic cell line installation should stay ahead of the product curve and TE should consume the excess, which ideally should cover the costs (even if margins aren't great compared to vehicles) of the Panasonic lines, so that less cash is needed overall. As production ramps, switch cell lines as needed, and keep adding more cell lines. Eventually TE production will be plentiful once lines are ramped at all GF's as the total cell production capacity should be well beyond vehicle needs.
TL;DR : Pickup and Y should be high volume, and probably need at least two North American production locations (GF5 and either GF6 or what's left of Fremont+GF1), necessitating at least one if not two new NA GF's to be built. I think that by intelligently building cell lines ahead of production and using them for TE that a good portion of the costs can be covered, reducing the need for cash from Model 3/S/X sales. GF3 (China) / GF4 (Europe) should be largely funded by local debt and thus not impact this (but I assume Tesla still can't get favorable debt financing because Wall St and must use cash for NA growth). S/X line under-utilization will be fixed when they move to 2170 cells from GF1, and S/X are not good truck platforms. Semi may be built at any of the above locations, Roadster likely only at Fremont. At the rate of cashflow generation they're getting from Model 3 I don't think any of these are a problem in terms of costs, only in terms of timelines (time to build the building that houses the machine to build the machine ... ) if they want to get to volume production of any of Y/pickup/Semi in 2020. If they can get the buildings built in the next 6-8 months I don't see why they can't at least be doing initial start of production at the 10's or 100's per week range of Y/pickup/Semi by end of 2019, assuming they've been planning ahead and really learned from Model 3 this time (like they claimed to have learned from X, and S before it...).
We're ready. I just don't think there is the political vision to look past the next election. Shame on us if we can't make it happen in Texas, 2nd largest US car market, largest truck market, made in Texas, etc. Come on Abbott, grow a pair.Tesla will probably work to get a sweetheart deal in another state, or flip an anti Tesla state (restrictions on selling) with a factory deal to build the Y.
(a) the land was cheapTesla currently owns almost 4.5 square miles at Sparks so they are planning something...
No, because none of this is remotely relevant. Remember, this is in the context of *trying to build a company town* because there isn't any *housing*. And trying to secure water rights to build the company town, because housing is *currently* limited by water rights. (You think the developers would let themselves be limited by that if water was cheap for them!?!?)Do I really need to keep going?
Water is not and will not be an issue. Want me to get specific? Look downstream on the Truckee River, starting at Fernley, or upstream at Sparks. Note the farms on the river. Tesla could buy them with pocket change.
The Board not shareholders vote on the Chairman.That's not what the settlement says. The nomination has to be within 45 days, but not the vote, and there's nothing about the person having to be confirmed in the agreement.
Tesla's charter lets it operate without a chairman. No ambiguity. If there's no chair, the CEO takes on the duties of the chair.
Testify!
I don't want to go all-out Nathaniel in this forum, but give me some time to explain to Kimbal how aquaponics uses juuuust about one-tenth the water of trad farming and pollutes infinitely less than Hydroponics... we'll (I and my Aussie buddies) wrap this sucker up all neat and tidy. "The Martian" could have just stayed on Mars and waited out the next expedition...
I'm not saying it's not doable, I'm just saying it's long-term cheaper to build the factory next door to Niagara Falls.Wondering how Musk would handle that sort of response.
Not enough water to support a town of 10,000 people.
So does the cost of importing water daily by truck to support 10,000 people stack up on a cost/benefit basis?
I don't understand what you are asking - but, in general what the market considers "worst case" is not what either of the parties might consider bad.Isn't the worst case that nothing changes? As a foreigner I'm not understanding why markets would be suppressed when on "nothing to a win".
I really hope Tesla doesn't try to pull a "sticking only by the letter" - not the spirit on this. They should just appoint a chairman and get him/her confirmed - if it is a simple board vote. End of story. Its simply not worth revisiting this - put it behind them and get on with the mission.That's not what the settlement says. The nomination has to be within 45 days, but not the vote, and there's nothing about the person having to be confirmed in the agreement.
Yes, one would think so. But, there is no indication the market has actually taken into account the political risk. It has completely ignored it. It didn't even think a second about the raising Trump - North Korea heated rhetoric, for eg.Market traders are currently terrified by Trump's wildly erratic behavior, especially the randomized tarriffs, randomized sanctions, and frankly, the Presidential hints that he'll treat people better if they divert business to Trump-owned companies.
Or not ! Because market loves their tax cuts ! They absolutely love tax cuts even at the risk of fascism or apparently even nuclear war.The Republicans are basically rolling over and doing absolutely anything Trump asks, even when he's acting nuts. If the Republicans retain the House, the market will crash.
Tweety did not have the guts to put this article under his name
Who's Fact Checking on the Tesla club forum?
Obviously for Dems, the worst case is status quo (with Republicans picking up seats in the Senate). For Republicans the worst case is losing both House & Senate - and a bunch of Governor's races.
The market would have already taken the expectation (House to Dems, Senate no change) as a given. If that happens, the uncertainty would be lifted and that should lead to atleast a modest bull run absent any new bad news.
If something unexpected happens - its not clear how the market would react. Most probably, continue the bear phase - or if Republicans keep the house (and Senate) - a big jump up in the hopes of another tax cut ?
Qualitatively there is no difference to the market whether Dems pickup House or both House and Senate. In both cases, probably not much legislation would get passed (even though, it is possible Trump will sign some of the bills Dems send him, because he likes making "deals"). But most probably, next 2 years will be like Obama's last 6 years. Nothing gets done because of a divided government. Apparently the market likes nothing gets done - so they like divided government.
