Ugh. Another Model S fire - 2013-11-06
omgwtfbyobbq
1,450
1,612
Southern California
I don't believe NHTSA's goal is eliminating battery pack fires. The entry at NHTSA says that they are assessing the risks of undercarriage damage. That's all. Even if the pack catches fire, as long as the occupants are safe then there is no need for modifications. Most likely, the NHTSA will link the damage with the low ride height, which can be easily changed via software.
I don't think the goal eliminating them, but minimizing them, and ultimately improving overall safety. There was a similar investigation of the Volt, and that was due to a fire that happened three weeks after the car was subjected to multiple crash tests. This kind of fire was not seen on the road. The end result was a voluntary recall by Chevy. If the NHSA determines that these weren't freak incidents, I imagine we'll see a voluntary recall from Tesla once they have designed components that can minimize the risk of battery fires.
stopcrazypp
9,862
4,797
But the NHTSA did not find anything wrong nor requested them do any action and GM phrases it as "a voluntary customer satisfaction issue" (even though all the media reported it as a recall). If NHTSA has similar findings, Elon already said he won't do a recall.
http://www.nhtsa.gov/About+NHTSA/Pr...ent+on+Conclusion+of+Chevy+Volt+Investigation
http://www.autoblog.com/2012/01/05/chevy-volt-will-receive-safety-enhancements-but-dont-call-it-a/
For reference, there's what Elon said about what he would do after the investigation:
While we think it is highly unlikely, if something is discovered that would result in a material improvement in occupant fire safety, we will immediately apply that change to new cars and offer it as a free retrofit to all existing cars.
http://www.teslamotors.com/blog/mission-tesla
It says "occupant fire safety", not "preventing a fire from happening" and I think it's worded that way on purpose.
jerry33
Mar 8, 2012
19,516
21,710
Texas
Of course. There is no way to prevent every kind of fire. If there was, we'd build houses that way and save the fire insurance premiums. I believe Elon has said that they design for when a fire happens, not if a fire happens, because fires will sometimes happen and it's a matter of "when", not "if".
Gynob001
Closed
Aug 1, 2013
171
12
Orlando
What do we do if we see an object on the road that could do damage? With other cars, we try to swerve to the next lane or get the object between the front tires. In case of Tesla, any guidelines?
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,582
Central New York
If you can safely swerve around it, then do so, obviously, otherwise, I think you still need to straddle it, though you might try to bias it to one side instead of right down the middle. That might allow you to miss the forward most pack module. If you have a 60 I believe that module is empty so it might not matter.
Theshadows
1,947
221
PA
That is an interesting question. Perhaps it would be better to take the hit on the tire if you think it may be something that would puncture the tire.
Did you see Elon's tweet last night?
@elonmusk: RT @mgalimany: @TeslaMotors @elonmusk This is what happens when your car is not a #Tesla Model S.
Dangerous Trailers.org Presents Road Debris Impales Car The NTSB does not care! - YouTube
This will never happen with a TS
GSP
2,565
795
Great video. It shows how dangerous road debris are, especially without a battery pack to protect you.
GSP
AudubonB
One can NOT induce accuracy with precision!
Mar 24, 2013
7,966
25,782
Usage police here, nothing more:
LATEST fire is what would be correct. LAST implies there are to be no further ones. As fervently as we all desire that to be the case, grammar+logic requires the former....
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
If you can't swerve to avoid the debris then I would plant the brakes. It's the one thing you can do to reduce the impact energy. Also hard braking will lower the front of the car due to the weight transfer, and this might cause the object to dig into the car in front of the battery pack, instead of hitting the pack itself.
ViperDoc
Roadster 1305
Jun 24, 2011
417
209
Vermont
Avoiding debris
Of course, the other thing we could do would be to not follow so closely on the tails of the car in front of us to give ourselves more reaction time to brake or swerve. I remember when I took drivers' ed years ago and was taught 1 car length for every 10 mph. That clearly isn't realistic since people cut in front of you, but I see many people following at distances that are clearly too close no matter what car they are driving!
