j6Lpi429@3j
Closed
on the 21st september i think this forum should respect a moments silence for the fact that the southbound fleet M3 supercharger started construction 2 years ago and is still not open ![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
does that mean red don't have any CCS?
Burtonwood today
Only 2 out of 8, and none of the 4 CCS chargers there! 3A&3B!
Only 2 working and no CCS?
Burtonwood shows light blue on the map but should be dark blue as it usually has 4 not 2 when working.
Hopefully they are being upgraded...
Oxford now has all 16 stalls live but not all with CCS: a check-in on the Supercharger app from a couple of days ago says "the first few stalls as you arrive do not support Model 3 charging"; a check-in on the Supercharger app from April indicated 6 with CCS so 6 minimum....
4/6 Oxford, UK - don't think that is right, Oxford has more than 6 stalls I think?
The in-car map will show you details of all superchargers I thought? feint ones are just out of your current rangeOxford now has all 16 stalls live but not all with CCS: a check-in on the Supercharger app from a couple of days ago says "the first few stalls as you arrive do not support Model 3 charging"; a check-in on the Supercharger app from April indicated 6 with CCS so 6 minimum.
Does the Tesla app show availability depending on your car type (a bit like the in-car map?). If so any Model 3 owners who are close enough to Oxford may be able to confirm #CCS stalls from the Charging tab (I'm not much use as I can only see as far south as Edinburgh using my phone, and ~Northwest England from the car map).
Admittedly I haven't checked recently but there seemed to be two limits on the in-car map - bold/faint to show in range/out of range, and then a further limit beyond which live stall availability isn't displayed. Last time I looked at this the latter limit extended to roughly Liverpool/Manchester from NE Scotland, so maybe 250-300 miles; anything south of that point didn't have the little red bars graphic.The in-car map will show you details of all superchargers I thought? feint ones are just out of your current range
The crowd sourced database may have been undone by the fact that Oxford was expanded and relocated within the car park - originally there were 6 bays then 16 new bays were built in 2017 but there was a period when some of the old bays were still live plus some in the new location, and then the old bays were removed but not all the new ones went live. As recently as July at least 2 of the 16 weren't working but this month all bays now seem to be up and running. You'd need a particularly well-designed database to capture all that history (on top of the CCS conversions)!The crowd sourced data still has 6 stalls (total) [which is not particularly important in this context] but only showing 4 CCS stalls, so would be good to have confirmation of that (My guess is that you can do that on a Model-3 SatNav even if not close? My Model-3 isn't here ...)
this image proves it... im not going to wale!s
