I agree Vostok. Its not ideal mate. For large city people its not necessary thankfully.
Given though my use case involves rural/remote stuff and particularly given Farmer Joes propensity for ultra dodgy machinery shed wiring Im forced to deal with rare edge cases. Moreover I want whatever "system" I have to be entirely independent of any human thought or education on behalf of the operator for safety.
Using a retail extension cord off the shelf from say bunnings for domestic 10A and 15A applications is a really bad idea.
Do the maths mate. It certaintly isnt AS/NZ compliant on cable length runs for continous current at 15A. Those so called 15A extension cords are not rated continous. As far as I have seen when researching all this topics, there is no retail extension cord adaquete for the task meeting continous ampacity to the AS/NZ code. Youd have to custom make one using diameter copper wire meeting the AS/NZ codes for continous use on the cable run. Do the maths on 10A continous with the so called 15AMP wire diameter found in extension cords at bunnings etcetc. Bunnings dont sell anything off the shelf thats safe.
Using retail 15A and 10A extensions on domestic plugs thats guaranteed to give problems in 10A and 15A use cases. Tesla derated both to 8A and 12A and currently it isnt possible to firmware upgrade the UMC to not derate it. Many people assumed they were getting the full when they are not in the Tesla UMC.
The other problem, what do you when you need a 32A 5 pin 3 phase extension as is common in remote areas?
then what do you do when you are at an untethered type 2 station and cant reach that?
What do you do when in a remote area at night in the rain and theres only a 20A 5 pin 3 phase socket at the showground with no 32A 5 pin 3 phase socket anywhere at all and you cant reach their 20A socket either?
"Solving" carrying 5 extension cords around for different situations by using a portable EVSE with say a single 22KW 3 phase extender in between the tail and the EVSE, well problem one your now tied to that portable EVSE and if it fails in a remote area your forced to have the same backup. It also still leaves the problem of how to extend on untethered type 2 charging stations that wont reach the charge port.
a type 2 extension is the only way to cover all possible extension needs in one extension
The type 2 extension cord using more than 22KW is so so so theoretical and fringe Im struggling to figure out how to test it to show that situation. There is no EVSE portable sold capable of more than 22KW AC so all those portable EVSEs will be setup to instruct the systems not to use more than 22KW, There is zero concern there. It cant ever exceed 22KW in that use case.
Raking my brain really hard on how the hell this could ever be tested of using more than 22KW in an type 2 extension cord situation the test would have to involve:
a) Goto WA to find one of these bizzare type 2 AC charging stations capable of throwing more than 22KW AC via type 2 IEC 62196. Any other situation has no concern at all.
b) Somehow amongst every BEV ever sold, find the unicorn vehicle capable of more than 22KW which is apparently the unicorn that is a Renault Zoe
c) Then test. As much as I respect Zombies facts and helpful insight here, I dont agree with this theoretical conclusion that this most bizzarre combination would in fact result in a concern. Hes making assumptions on the test result. Im still waiting on the cable extension to arrive but for the sake of argument if has no smart chip in it, it has no resistance signalling and so on which I think is highly highly unlikely but lets just assume for the sake of it before it arrives at my house it is indeed that way. Well what zombie isnt considering is this WA charging unit on type 2 capable of 45KW. I now have the specifications for IEC type 2 and there is multiple versions of the spec. There is detail about two areas in particular: temperature sensor and ampacity sensor. So its highly highly highly likely that his bizzare 45KW type charger in WA, even if the most simple home made type 2 extension ever was used with no chip in it and no resistance and no anything but type 2 standard plugs/sockets and 22kw cabling, its highly highly highly likely the overall system will derate to 22KW anyway. Its something Id actually really like to test. Whos in WA? With a Renault Zoe lol
Anyway if it turns out the type 2 extension I have has the chip in it or other mechanisms, then this ultra fringe case is solved that way without any WA testing needed.
There is no other solution that doesnt involve 5+ extension cords, which for 10A and 15A would have to be custom made theyre unavailable in retail, and then your still stuck on untethered type 2 cases when needing an extension there.
