OzTzlaBloke
lolNot sure how fiddling around in the fuse box is going to gain you 30 volts
I can log the voltages over time in true rms via bluetooth as more ammo on the supply
Another suggestion:Thoughts
I was surprised it was that low (the 216v limit)-A 63A 1N circuit is capable of 15kW continuous power draw without significant voltage drop as per Australian Standards - by design no more than 5% from point of supply to anywhere in the house. Any more than 63A draw will just trip the CB.
A 240V grid 5% drop will be 228V
A 208V at the charging plug during charging possibly means 219V at the supply side.
I am suspecting low street voltage to start off with, However, 219V is within Grid specs so the grid operator wont take any action.
Oh yeah. The operational voltage range is wide.I was surprised it was that low (the 216v limit)-
Check what the Tesla reports as you turn down the current draw. If it's resistive voltage drop, you should see it rise closer to the open circuit voltage as you drop the current.Measured 221.5 true RMS at a random GPO in the house. Meanwhile that minute the Tesla is saying 208v.
Did you get the grid operator check the street voltage? Another way is to turn off all the loads in the house and re-measure using the GPO in the meter box (if there is one)Measured 221.5 true RMS at a random GPO in the house
"Point of attachment"from the point of access,
Yes you pay for the upgrade and also the "Daily supply charge" in your electricity billdespite this being grid side stuff to fix it, means, the grid isnt responsible for paying lol
Why wouldnt you just charge the tesla slower over longer periods, and don’t charge it at all on days that the aircon needs more draw or other appliances such as oven/cooking are on?If we assume single phase 63A domestic on 16mm wiring not just mains supply from POA to fuse box but the POA to the power pole as well which is a 29M cable run from POA to Pole. Im still getting concerned around amperage given one Tesla will pull 32A no problems given the size of the battery banks its only a fractional C rate @ 32A. So its more or less continous while charging @ 32A, only when its off does it come back from that demand.
63A - 32A - Budget of 31A left
So Im doing an audit of typical use cases in my residence like a) always on wattage estimates b) "activity" type wattage estimates excluding big stuff like ducted reverse cycle air con. I have continous gas hot water and gas cooktops with an electric oven. Where Im confused is moving from the maximum amperage of the ducted air con to what it tends to average out at over a period of time. Similar to I know the fridge will pull hard on start then settle around 550W ongoing.
31A left where the plaque on the air con is saying max draw of it can be 27.5A jeezz wow
So my concern would be allot less if the nominal ampacity was like 12A and not say pegging to 27.5A 88% of the time. I'm in the dark here guys.
I know that I have no house side master breaker only a switch. The only big master breaker is that supply side 80A fuse which according to the meter swap sparky wont blow on momentary spikes and basically takes a crap tonne to actually blow it wont go on 81A or anywhere close. So I believe I can do like 90A-100A, as the smart meter now installed I think wont be happy beyond 100A. Atleast on spec reading the new smart meter.
Sorry guys for the long posts. Ill try to give back things I know with putting in the time here to help other topics out that I know well. This stuff Im not very experienced in with residential power.
That AC unit is rated at input power of 3.12kW (cooling) / 3.59kW (heating) - that's 14A / 16A. The 27.5A would just be worst-case brief surge at startup.So my concern would be allot less if the nominal ampacity was like 12A and not say pegging to 27.5A 88% of the time. I'm in the dark here guys.
The best person to speak to would be your electrician. But I think you should be Ok assuming the supply side to house is OK - especially charging overnight when loads are lower.So my concer
80A. Never go beyond "rated". It's not about how close you can get to the breaking point.So I believe I can do like 90A-100A
Do you have electric hot water? That would usually be another 15A when it's heating.
Thanks so much. Cafz did you look that data up elsewhere? Where/how did you figure out those amp values?
