sorka
Hmmm... maybe I'm wrong. I really think I've seen this... but...
Tesla Model S P85D Insane vs Sport Mode Testing 0 60 MPH in 3 17 Seconds - YouTube
Also tends to support 480kW. And he had separate G gauge showing 3.2 seconds. (Appears upper right, several seconds after the run).
As soon as my car is back together I'll measure (video or some other accurate means). Will be a day or so. Car is currently in pieces for some accessory work I'm co-developing with Artsci.
In both cases, the KW peak hit the same spot on the meter (just below 480) but in the second run, it took a lot longer to get there.
On the first run insane mode, the draw peaks at 40 MPH.
In the second run, it peaks at around 55 MPH.
- - - Updated - - -
Yes, it could be traction. Tires had some abuse lately and 7C was not ideal. I found my vbox today and couldn't get less than 4,1s 0-100 in near ISA contiditions. That's why I prefer 100-200 and 0-200 measurements. Traction becomes insignificant.
It IS traction. Your second video shows the traction light coming on which only shows after traction control has ALREADY been activated. The light only shows after a certain threshold is seen. i.e. traction control can be limiting your 0-60 even if you don't see the light but it goes beyond a certain point, the light will show. It's likely your first video also had traction control but was just under the threshold for the light to show.
