Turbo3
I posted the equations I use on the Tesla battery topic. I think you even commented on it way back then. But you will also need the next version which fixes some features (now bugs) and supports full hex in the recipes. The right side scale was not originally designed for fractions which means the current release uses integers to set the limits which does not work well when displaying voltages that vary by a few miliivolts.Something is strange with decoding these groups of 14 bits ...
are these bits high order on the right instead of on the left?
If so, we are going to need a way to reverse the order of the bits in a byte,
like making the byte # negative to flip the bits from right-to-left to left-to-right.
WAIT, WHAT DID YOU DO TO MAKE IT WORK ... recipe for Plot, please?
I am not happy with the way post filtering looks when first displayed (blank graph because the zoom level is screwed up due to so much of the data being filtered out. I may hold off with the release until I decide how to handle this. You need to manually zoom in a lot before the graph starts to appears.
There are a few ways to handle this I just don't know which is the best at the moment. May need to experiment which will take some time.
I could pre-process the array and remove all the filtered data but then if you select a different plot I need to restore all the data to view it unfiltered or with a different filter. I could have a third array I copy over all the filtered data into meaning I now have three data areas.
