The Plot Recipe lines for Brick Volts (hopefully correct):
PT:Brick Volts:V1:v, 2, 255, 6, 3, 252,-2, 0,5, 0,0.000305,0, 2,1,255,3,1778, 0,0,0, 0,0,0
PT:Brick Volts:V2:v, 3, 003, 12, 4, 255, 4, 0,5, 0,0.000305,0, 2,1,255,3,1778, 5, 240, -4, 0,0,0
PT:Brick Volts:V3:v, 5, 015, 10, 6, 255, 2, 0,5, 0,0.000305,0, 2,1,255,3,1778, 7, 192, -6, 0,0,0
PT:Brick Volts:V4:v, 7, 063, 8, 8, 255, 0, 0,5, 0,0.000305,0, 2,1,255,3,1778, 0,0,0, 0,0,0
I discovered that the Recipe items Mask and MsgID cannot be written in hex, like 0x6F2 for 1778.
It would be handy if the 0x... hex values were accepted ... in some future version.
Remember, in v0.0.16, that the Byte D# values are ignored, but this Recipe should still work now.
Questions:
1. If we did not use the filter when capturing the 0x3F2 messages, would the capturing be able to capture all the messages in each clump? At 8 values per module / 4 values per message ... that is 32 messages in a clump. If the 32 messages are too big of a clump, perhaps we could filter for half, or a quarter of the messages, by using a Mask C with some bits set to zero.
2. Assuming we can capture clumps of some size, does graphing use the Byte C# values to filter the captured data for the purposes of display? If not yet, in the future perhaps?
If we can do both, that would be very helpful, being able to capture all the voltage and temperature dara at one time, and then be able to see any brick voltage and/or module temperature, 4 at a time. In the future.
