Building a TM-Spy Adapter
Caution: If you mess this up, you might hurt your car.
Please be very careful, the info below might contain
errors, and I take no responsibility for anything you do.
1. OBD Part: One way to get an already wired Female OBD connector ...
buy an OBD splitter cable, 1 Male to 2 Female, less than $10 on Amazon.
You could buy an OBD extender cable, but it has just one female end
to use, not two, but might be a better choice if you want a long adapter cable.
Or, just order a female OBD connector and matching pins from Mouser,
and use a much more flexible 4-wire cable, suitable for your application.
2. Identify Wires: Cut off one Female "leg", carefully expose the wires, and determine
which wire go to the OBD pins 4, 6, 14, and 16, possibly using a volt/ohm meter.
Or, if wiring an OBD connector, use 4 wires of suitable length, crimp 4 of
the OBD pins onto the 4 wires, and insert the pins into locations 4, 6, 14, and 16.
3. Crimp TDC Pins: Attach the 4 crimp pins that fit the connector housing on the
adapter's TDC end. Crimp (and possibly solder) the 4 identified wires to the 4 pins.
The connector that mates with the TDC is shown below, with the matching pins.
They can be ordered from Mouser.
4. Insert Pins: Carefully insert the 4 pins into the correct holes of the TDC header.
The pins will go in two ways, but only lock in place when inserted correctly.
Caution, do not make a mistake, since the pins are "impossible" to remove.
So, double-check each pin's OBD connection before inserting the TDC pin.
The wire from ...
OBD pin --> to TDC pin:
4 --> 9 (ground)
16 --> 10 (power)
6 --> 1 (CAN3-H)
14 --> 6 (CAN3-L)
5. Obtain an ELM "clone/ copy" that actually works. Some do not.
However, many look almost the same. Suggestions later.
6. Plug the adapter's TDC end into the Tesla's TDC connector
and test for Power (and Ground) on the OBD end's pin 16 (and 4).
7. Plug the ELM into the adapter's OBD connector. If it is like
the ELM shown below, the power led should illuminate, as shown below.
8. Pair the ELM to your Android device, then test the app.
When it all works properly, you might wish to place the adapter
and ELM into the recess space above the cubby, and close the cubby.
9. Test everything again, and ... enjoy using/testing TM-Spy.
If you are not qualified to do this work, please get proper help.
If you have questions, please ask first, before making an error.
Note: Some Model S's, manufactured after about Sept 2015, have
a different connector for the Tesla Diagnostic Connector (TDC).
We have yet to find a source for a mate for it.
Cheers, Gary
