Turbo3
TM-Spy version 0.0.9 has been uploaded.
- Graph zero line changed to Green
- Stacked graph scale improvement
I will restrict the Histogram to a 50 mv minimum scale to avoid that problem.
For the 25 and 50 mV scales on the battery cell graph the number of digits after the decimal point for the voltage number was increased from 2 to 3 which does not leave room for the full y axis name (50 mV) or any axis label (25 mV).
The axis caption shows just fine at the old 50 mv and the new 25 mv scale settings.
So, you might want to leave the new 25 mv scale, just eliminate the new 10 mv scale,
since it does not really add anything of real use.
So, just a different style, which works better for me, I guess. Sorry if it annoys you. Cheers, Gary
Since the MS appears to charge the 12v battery several times
a day, I presume that leaving the ELM plugged in will not matter
very much. I left mine plugged in for a few days. When active
with the Android device, recording data, that is likely to draw
noticeably more current, but that should work, but I have not
yet tried it.
