So, with all the discussions about the Model 3's 12V frunk opening system, I thought it would be interesting to see what would happen if you didn't use a 12V portable jumpstarter... but rather a standard 9V alkaline battery.
Yeah, if OP is feeling brave, try disconnecting the car's 12V battery and see what happens.A true and trusty pioneer, you are!Huh, I wonder if it's using a boost from the 12V and that if the 12V was truly dead you'd have to have hook up a 'proper' supply?
It also quickly brings me to the question, can I set up the frunk opening to alert me on my phone. Because the 'kids' are surely going to get wind of this very quickly.
P.S. Is your car ever dry????![]()
The idea was to see what would happen if the 12V battery in the car were depleted. Rather than trying to abuse your battery, I suggested you just disconnect it. Of course, the battery would be present and connected in most cases. I guess the disconnected battery may not be a good substitute for depleted battery, though, if the electrical connection from front bumper relies on the battery being there somehow. Only one way to find out.The sole use for this would be to open the frunk. I think the concept of using the portable 12V jumpstarter is that you use it to open the frunk and then recharge the main 12V battery. This would only be useful to open the frunk and then you're stuck again.
I suppose this would allow you to keep a portable 12V jumpstart battery in the frunk? Then you just need a 9V somewhere on the exterior of your car and you never have to worry.
The idea was to see what would happen if the 12V battery in the car were depleted. Rather than trying to abuse your battery, I suggested you just disconnect it. Of course, the battery would be present and connected in most cases. I guess the disconnected battery may not be a good substitute for depleted battery, though, if the electrical connection from front bumper relies on the battery being there somehow. Only one way to find out.![]()
(2) A standard alkaline AA battery did not open the frunk. The AA I used was outputting 1.623V. So, clearly the frunk needs more than 1.6V. Furthermore, it's some evidence that it doesn't use the existing 12V to supplement the power requirements to open the frunk.
I keep my Noco GB70 in the frunk too BUT the Model X has a manual emergency frunk release, unlike the M3's.
We are driving our MX the 4000kms across Australia (hopefully the first MX and a proper family vacation) in June/July and this coincides with the 12v battery dying and the keyfob batteries simultaneously going flatOur first supecharger will be 2600kms from our start point and I don't know about Tesla's response time to a break down on the Nullabor.
If you don't have at least a 12V trickle charger and the 12V battery is dead you aren't gaining much opening the frunk.....unless you store the trickle charger in there...but why, and that's a lot of baggage to pack around for very rare edge-case benefit.
A portable jump starter isn't a lot of baggage, these days. This one is will crank a 6.5L ICE:
https://www.amazon.com/DBPOWER-18000mAh-Portable-Starter-Charging/dp/B01D42TYFC/
For a Model 3, it should require much less current, so you could get away with something even smaller.
Turn on security alarm feature and when your frunk gets popped open when you’re not around. You’ll be notified by the app and by loud blaring sounds.
Also in jersey. My 3 haven’t been dry since I bought it.
I have a DBPower and they're great little devices, but they're still not small enough to keep outside your Model 3. They're also not great for temperature extremes. This whole thread started with the thought of "What's the smallest, most convenient way to open the frunk in the event of a 12V power problem?"
In my original frunk opening demos, I specifically used the:
https://smile.amazon.com/gp/product/B074WM8855
This one is 8000mAh for a "Gas Engine up to 2.5L" However, I don't know how much is required to get the Model 3's 12V battery back up from a discharged state to one where the car can be turned on.
Very good info to have!
Now can you open the glove compartment without power?
