What's going on
Hi All,
I realize it's been a long time since a release so I thought I'd give an update on what I've been working on.
There's been a lot of activity restructuring code. There will be no user-visible differences from this restructuring other than squashing some bugs. I'm doing this primarily to make the code more maintainable. Because of the scope of the changes, the next version 0.29.00 will be labeled experimental.
I've added some features that have been requested such as the ability to permanently override certain car characteristics. For example, if you switch your tires (and wheels) in the winter, you can tell VT to display the actual tire on your car as opposed to what's programmed into the system. There are a couple of changes to the Overview Tab. You are now shown the shift state (park, drive, neutral, reverse) and the range of your choice (estimated, ideal, or rated). There's also a new feature that will send notifications if a charge anomaly is detected. This is extremely hard to test, so it will also be considered experimental.
There's more and it will all be in the release notes as usual. Hopefully I'll have a chance to release the new version sometime this weekend.
Joe
Hi All,
Joe
