I have a Model X only 3 months old. Have the same issue - voice command button not working, but will activate if I honk the horn. Started having the problem after I updated software to 46.2...maybe a coincidence. Called support and they said it was a known issue. Have to carry to Service center to resolve. Appointment scheduled for Friday.
2018 Model S. Having same issue. Voice command and scroll wheel not working. Bottom menu button works.
Pressing horn activates the voice command. I am able to do a reset by pressing both scroll wheels.
Does anyone have the fix for this or does it need to be replaced?
Had it on for service. I told them the problem prior to bringing and they said they ordered parts.Just had it repaired on my X. Replaced the entire air bag module
Hi. I had to replace again the entire set, in about under a year. I still had the old set, so I tried to replace just the voice activation button, but it still didn't work, so I had to buy another set, I guess was the harness that was damaged. It worked fine since.Any updates / resolutions? Just started on my late 2018 S75D. Same issue as others are reporting - voice command button travels/clicks but doesn’t activate, horn activates voice command, and opening drivers door to enter activates voice command.
