You are in Colorado, and it's late October. I am guessing it was not a balmy 80 degrees. If the battery is cold, it has to start off charging with low power (or even no power if it's REALLY cold) until it can heat up the battery more to increase the charging power. So did the car sit out overnight and get cold, and then you just drove to the Supercharger first thing in the morning? That could easily explain low power there.It was like charging at home which was lame..last time i used a sc a year ago it was at least 150kw..
i was on the way back from dropping off someone at dia..so had been driving the car for like an hour or so....it wasnt cold...but i remember driving to wisc and using sc 2 yrs ago and it was alot higher in 0 degree icey weather- also i unplugged yesterday and tried a diff charger at same place and still 40kw...maybe tesla throttles free supercharging for life people?You are in Colorado, and it's late October. I am guessing it was not a balmy 80 degrees. If the battery is cold, it has to start off charging with low power (or even no power if it's REALLY cold) until it can heat up the battery more to increase the charging power. So did the car sit out overnight and get cold, and then you just drove to the Supercharger first thing in the morning? That could easily explain low power there.
Definitely not.maybe tesla throttles free supercharging for life people?
Stop exaggerating please.It was like charging at home which was lame
That does sound good, my wall connector Gen 3 setup is 11kW 48A.Sounds like you have a great setup at home though, if your home charging is 40kW
i had like 60 miles left....when i got there and stayed till 70 cause it was so slow...i could have made it home on 60 but i thought i would stop on way back from dia airport for the hec of it.What was the SOC when you started charging? Normal for cars at 80% SOC to get about 40 kW, and tapering down from there as it charges. Could also be something wrong with that specific Supercharger. You might try another at an entirely different location.
Some 2020 S Teslas have unlimited free supercharging. This was early 2020 when Covid was first affecting sales. I have one.except for a few rare 3's... a car with unlimited lifetime free supercharging cannot charge at 250kw due to the age of that vehicle and the older battery tech...
Tesla Model | Year(s) | Unlimited Supercharging status |
Model Y | 2020-2021 | None (Unless you purchased in late December 2020) |
Model 3 | 2018-2019 | Performance trim only and must be original owner |
Model X | 2016-2020 | Potentially available, confirm with Tesla |
Model S | 2012-2020 | Potentially available (excluding the S 40), confirm with Tesla |
Did you navigate to the supercharger on the GPS? This enables battery preconditioning which allows for faster charging speeds.i had like 60 miles left....when i got there and stayed till 70 cause it was so slow...i could have made it home on 60 but i thought i would stop on way back from dia airport for the hec of it.
I have navigated to superchargers Tesla inserted on my route in mid winter, and some notify you of preconditioning, and do, while others do not precondition and no notification. Tesla programming as we all know sometimes works and sometimes doesn't.Did you navigate to the supercharger on the GPS? This enables battery preconditioning which allows for faster charging speeds.
Just driving to the charger without specifically navigating there won’t precondition.
