We ordered a new M3. We drive about 20 miles a day and 40 on Wednesday’s.
What’s the best way to charge to minimize battery degradation.
Charge to 90% one time and run it down to 30 over multiple days. Or charge to like 50/60% each night?
Thanks
This is very easy. A Lithium-Ion battery is most comfortable at 50% SoC. So ideally your SoC is 50%, always. But of-course, when you drive it goes down.
So, if your daily commute uses 20% SoC the best percentage to set charge limit is 60% so you drive from 60% to 40% and then charge to 60% again. If your daily commute uses 40% the best percentage is 70% so you go from 70% to 30% and back to 70%
There is a 'but'... The difference in health effect on the battery go down considerably when you keep it closer to 50%. For example:
The battery health difference in always charging to 90% instead of charging to 100% is pretty big.
The battery health difference in always charging to 80% instead of 90% is there, but considerably smaller.
The battery health difference between a default charge rate of 70% instead of 80% is probably close to irrelevant.
And battery health difference in charging to 60% instead of 70% is probably something you might not notice at all.
So, keep it to 50% as close as you
comfortably can. It shouldn't be a hassle. For example, if you might be called away for an emergency that requires 70% SoC while you usually can do with 60%, I would always set it to charge to 70%. 'Just in case'.The difference in battery health in charging to 70% instead of 60% is so small, it's more for the fun of keeping your battery in best shape than it should be a requirement. If 80% or 90% feels more comfy, please just set it to 90%.
The long term effect is minimal!
Additionally, when you live in a hot climate it's best to charge at night, when it's cooler. Li-Ion batteries prefer a temperature between 20 and 25 degrees Celsius. And yes, the car will cool the battery when required, but not down to 20-25 degrees.
