Waiting for the worst of the summer sun to see how much I miss that.read thru all posts and most of what has bugged others doesn’t bother me. To pick one thing I think would be lack of ventilated seats. Probably miss that the most.
Sure, I have a laundry list of things I don’t like, but...
Closing the doors with the windows down just makes my entire body cringe. The sound it makes is one of cheap, nasty, econobox misery. It might be worse than any car I’ve experienced. Even thinking about it makes me want to curl up in the fetal position and cry. (Hold me?)
So, what’s your biggest bugbear with the Model 3?
QC...QA whatever
Since being a member of this forum gave me doubts about my order. More and more everyday
Anyone dislike the two small circles when adjusting the speed of air vent?
Those are so small compare to the empty space around the screen function, makes it very hard to hit it when you are driving in not a smooth road.
Think I know what you are referring to but to adjust flow I almost always use, on the white moving air flow display itself, index finger to swipe up or down to change air flow direction and thumb and index to pinch or expand fingers to split the flow of each vent area. Seldom use the slider controls.
Oh, I thought it was a vision system so that it uses the cameras themselves, not a separate sensor, but that's just my assumption.Good idea. I assume the sensor is center top, above or below the front camera?
The blinkers kill me! When used manually they should work manually.
The 'quick tap' should get you three blinks then stop. it's never consistent \ they seem to have a mind of their own.
Half the time they stay on or you push the stick in the other direction to stop them and they reverse.
Makes drivers behind you think your an idiot driver.
