What has UV protection?
Discussion in 'Model X' started by Ritium, Aug 10, 2016.
  1. Ritium
    Ritium New Member
    Aug 8, 2016
    LA County
    Recently ordered my X and trying to be ready with a tint solution. From what I can tell, the windshield is the only window with UV protection. Is that true?
  2. kazkioken
    kazkioken Member
    Apr 18, 2016
    Los Angeles
    My local service center said "all windows in the Model X have UV protection". I put ceramic film on the front 2 windows regardless to get some heat out of them in sunlight.
  3. alseTrick
    alseTrick Active Member
    May 17, 2016
    Florida, USA
    My understanding is:
    That's correct. But only the darkened glass segments offer increased levels of visible light and infrared reduction.
  4. scottf200
    scottf200 Active Member
    Feb 3, 2013
    Chicagoland ModelX S603
    All windows may have some level of protection but I don't thin the front driver/passenger side have any more than standard cars which is like 65%. Have been other threads on this. I also added tint to my front windows after I got the X.
    Below via quick google search: Not All Car Windows Protect Against UV Rays
  5. tomtx37
    tomtx37 Member
    Jun 21, 2016
    Which ceramic film did you use to tint your front 2 windows?
  6. Texas
    Texas Supporting Member
    May 19, 2015
    Houston, Texas
    #6 Texas, Nov 8, 2017
    I have 99% UV protection in both the fixed and the sliding parts of the panoramic roof and in the glass of the liftgate of my May 2015 Model S. I can report this with certainty because I crawled up on the car and read the imprint on each of these three parts of glass. The operative word printed on each one is "LAMISAFE," which I found is a brand name of a Japanese company, AGC. Wikipedia reports that AGC is the largest glass company in the world and a core Mitsubishi company. Lamisafe is a widely-used laminated safety glass that filters out 99% of all UV rays, for which It has been awarded the Seal of Recommendation of The Skin Cancer Foundation, a U.S. nonprofit healthcare organization.
    I don't know if all Teslas use Lamisafe glass in their roofs and liftgates, but I'll bet they do. Not only does Lamisafe repel almost all UV rays, it also prevents sunroof "explosions" that are becoming the subject of controversy recently in cars that use tempered rather than laminated glass roofs.
    Windshields in all cars are required to use laminated glass for safety reasons, but for side windows (Tesla included) and roof glass most companies use tempered glass, which is strong and shatters into small fragments,when broken. Tesla is one of the few companies that has taken a more safety-oriented course by using laminated glass sunroofs.
    My Tesla has TEMPERLITE tempered glass side windows, as marked on the glass, which is also made by AGC. I don't have any information about UV blocking in this glass, although UV shielding is available.
    I don't have any similar information about heat filtering, other than the observation that my Model S doesn't get any hotter here in Houston than my other cars have in the summer--that is to say, very hot even if I crack the windows and the sunroof and unbearable if I leave the interior sealed.
  7. khalkhin
    khalkhin Member
    Dec 9, 2015
    Los Angeles, CA
    S owner here. I did lots of research into this when getting my windows tinted. I can confirm that Lamisafe is laminated glass and will block out UV. Laminated glass has a plastic layer that makes it both safer from a crash standpoint and a UV standpoint.
    Temperlite is tempered glass, without any plastic layer, and does not block out UV. Auto manufacturers continue to use it because they can save a few bucks - I think the difference is literally about $5 per window. Unfortunately, the S, like most cars, has it on the sides, but Tesla got smart and did not use it on the X.
    In my opinion it is well worth it to spend the money to get some tinting done if you have tempered glass in your (non Model X) car. Skin cancer rates on the left side are significantly higher than the right, just because people are getting UV through their auto glass while driving. You can easily find a tint that is barely noticeable and will block over 99% of the UV, plus reject 50% of incoming heat. I'd be happy to recommend a great installer if you live in Southern California.
