I'm assuming the range increase was due to software updates that at first limited your range, then later updates restored some that range. Our 11/13 built S85 had a 256mi range in early 2019. Range dropped overnight to 244 in mid-2019 and would fluctuate between 230-246mi for years. Currently the most I've seen lately is 240mi range with 112K miles on the car/battery. It's been disappointing and hoping to get some clarity in regards to a resolution. Some folks have been getting notices in the mail from the class action settlement, but I've yet to receive anything.I have been charging at around 50% to 100% for the last year....and my range increased from 221 to 244.
Have been changing the range setting from rated to ideal a few times, also to pct. On ideal its 305mi.
I have no idea what changed. But have been using the 'ideal range' setting bc its makes me feel better seeing 305 vs 220 at 100%.... but when switched back to rated range, saw the 20 mi jump....im sure you are right, its a function of the upgrades not my charging habit.I'm assuming the range increase was due to software updates that at first limited your range, then later updates restored some that range. Our 11/13 built S85 had a 256mi range in early 2019. Range dropped overnight to 244 in mid-2019 and would fluctuate between 230-246mi for years. Currently the most I've seen lately is 240mi range with 112K miles on the car/battery. It's been disappointing and hoping to get some clarity in regards to a resolution. Some folks have been getting notices in the mail from the class action settlement, but I've yet to receive anything.
Our charging habits is to keep the car charged between 25%-78% SOC and the car will typically sit in our garage for up to 3 days between usage.
The problem is the optimal charging strategy is kind of a pain, and also makes it look (to the untrained eye) like you can't use what you have. I.e. You have this huge battery, but only use 30% of it for the best long term health of the pack. To anyone outside the EV world (and lots in it) that just sounds nuts.It is unfortunate that Tesla does not communicate very clearly what the optimal charging strategy would be.
The Model S/X 85 kWh batteries are very resistant to calendar life capacity loss - I wish all Tesla batteries were as good in that capacity.I'm assuming the range increase was due to software updates that at first limited your range, then later updates restored some that range. Our 11/13 built S85 had a 256mi range in early 2019. Range dropped overnight to 244 in mid-2019 and would fluctuate between 230-246mi for years. Currently the most I've seen lately is 240mi range with 112K miles on the car/battery. It's been disappointing and hoping to get some clarity in regards to a resolution. Some folks have been getting notices in the mail from the class action settlement, but I've yet to receive anything.
I wasn't aware that the Model 3/Y saw such dramatic early range loss...I've been living in "classic" Model S-Land for a little too long. I've been reading through that huge thread here and there but nothing is really sufficiently definitive because:The Model S/X 85 kWh batteries are very resistant to calendar life capacity loss - I wish all Tesla batteries were as good in that capacity.
Your car has over 90% capacity remaining after 10+ years and 112k miles.
That is phenomenal.
That sudden loss of capacity in the 85 kWh cars was due to an issue with the BMS boards and Tesla, out of an abundance of caution, limited max voltage of the packs to eliminate the risk of overcharging. There's a huge thread in here which discusses that.
Now those batteries can't supercharge as fast as the cells used in the Model 3/Y and are really the only achilles heel - instead of losing capacity, they seem to lose supercharging speed.
In comparison, the Model 3 will lose about 10% capacity in 2-4 years for most users. My Model 3 is down about 10% coming up on 4 years now after following a mostly 70-80% charge limit the first couple years, but only around 30k miles. That said, the estimated range has been very steady the last year with no real trend in capacity loss detected. Maybe that's because I switched to the AAKEE recommended method of charging (charge to 55%, recharge when you need to, charge higher if you need to for trips), or maybe because the batteries lose capacity quickly the first 1-2 years, then quickly levels off. Or maybe a combination of the two.
Either way, 50% SOC is more than enough for any typical day of driving. My last car was a LEAF - trying to charge that to 80% to prolong life meant ~50 miles real world range until you start getting some real range anxiety, ~70 miles on a 100% charge, but that battery lost 25% capacity in 4 years.
when i finished a supercharger session part-way home, I made the error of disconnecting the charging cable before noting how much charge I had received from the charging screen; the screen disappears when the cable is disconnected. I knew that, but had forgotten the trick of stopping charging from the control panel before disconnecting. I rarely use Superchargers so I did not think out the steps correctly. So, no good data from this trip.
Right, if I had looked at the app soon enough, I could have done that and I should have. But once I got home and plugged in (again), that value disappears. I have only recently noticed that feature and did not think of it. Battery was pretty low (again) when we got home, and I was tired.You can see the amount you charged in the app, or on your account page on tesla.com....
Look at Charge Stats in the app. The picture shows one session because I'm touching that line with my finger.Right, if I had looked at the app soon enough, I could have done that and I should have. But once I got home and plugged in (again), that value disappears. I have only recently noticed that feature and did not think of it. Battery was pretty low (again) when we got home, and I was tired.
Looking now, my account page only shows that I charged, with no information about the amount of kWh. Perhaps that is because I have free supercharging, not sure. There are columns for charging fees, idle fees, and invoices, nothing for energy use.
But thanks for the suggestions!
I see no such screen in my app. Is that from the Android app, or Apple? If it is Apple, then it may not be available in the Android version I have. How do you get to that page? I looked in the app store and the sample pages do not show anything like that, and no newer version than mine seems to be available.Look at Charge Stats in the app. The picture shows one session because I'm touching that line with my finger.View attachment 803394
Pic below is main page of Android app. Choose charge stats.I see no such screen in my app. Is that from the Android app, or Apple? If it is Apple, then it may not be available in the Android version I have. How do you get to that page? I looked in the app store and the sample pages do not show anything like that, and no newer version than mine seems to be available.
Interesting, but my app does not look like that, which suggests I may not have the latest. My phone says that I have version 4.8.1-1032, installed on April 28 -- sounds pretty recent.Pic below is main page of Android app. Choose charge stats.
The store will say "update" if an update is available. Also, you must have FSD as summon is only available with FSD. My Tesla is a 2022 Model S without FSD. My app version is 4.8.1-1032Interesting, but my app does not look like that, which suggests I may not have the latest. My phone says that I have version 4.8.1-1032, installed on April 28 -- sounds pretty recent.
If I may ask, can you tell what version of the app you are running?
Also, I wonder if it matters what car you have. Mine is a 2015, so it may be too old to provide that data....just a guess.
The App Store does not indicate what version is available. Usually if there is a newer version, it says "Install" when you look at an app in the store. Mine says "Open" or "Uninstall," suggesting there is no newer version. Newer versions usually install automatically.
My app menu does not have entries for "Schedule" or "Charge Stats" but I have an entries for "Summon," "Service," and "Roadside," not shown on your screen shot but possibly just outside of your image.
I do not have FSD, but the very first version of autopilot, AP1, which I have, does include the Summon features (lane changing, self-parking, and straight summoning in and out of spaces). At some point, Tesla removed Summon features from the basic (free) version of Autopilot.The store will say "update" if an update is available. Also, you must have FSD as summon is only available with FSD. My Tesla is a 2022 Model S without FSD. My app version is 4.8.1-1032
Ok, that explains summons. I think you're right about data availability for different years, but I don't know for sure.I do not have FSD, but the very first version of autopilot, AP1, which I have, does include the Summon features (lane changing, self-parking, and straight summoning in and out of spaces). At some point, Tesla removed Summon features from the basic (free) version of Autopilot.
