This is from the current owners manual for my ravin model s(
2019.16.1.1
May 16, 2019
Controlling Speed Assist
To adjust the Speed Limit Warning setting,
touch Controls > Autopilot > Speed Limit
Warning, then choose one of these options:
• Off - Speed limit warnings do not display
and chimes are not sounded.
• Display - Speed limit signs display on the
instrument panel and the sign increases in
size when you exceed the determined
limit.
• Chime - In addition to the visual display, a
chime is sounded whenever you exceed
the determined speed limit.
You can also specify how the speed limit is
determined:
• Relative - The speed limit is determined
automatically based on detected traffic
signs and GPS data. If desired, you can set
a speed limit offset (+ or -) if you want to
be alerted only when you exceed the
offset speed limit by a specified amount.
For example, you can increase the offset
to +10 mph (10 km/h) if you only want to
be warned when you exceed the speed
limit by 10 mph (10 km/h).
Note: The offset from speed limit also
affects the number shown in the gray
speedometer icon on the left side of the
driving speed on the instrument panel.
• Absolute - Manually specify any speed
limit between 20 and 140 mph (30 and
240 km/h).
And under limitations:
Limitations and Inaccuracies
Speed Assist may not be fully functional or
may provide inaccurate information in these
situations:
• Visibility is poor and speed limit signs are
not clearly visible (due to heavy rain,
snow, fog, etc.).
• Bright light (such as from oncoming
headlights or direct sunlight) is interfering
with the view of the camera(s).
• Model S is being driven very close to a
vehicle in front of it which is blocking the
• The windshield is obstructing the view of
the camera(s) (fogged over, dirty, covered
by a sticker, etc.).
• Speed limit signs are concealed by
objects.
• The speed limits stored in the GPS
database are incorrect or outdated.
• Model S is being driven in an area where
GPS data is not available.
• Traffic signs do not conform to standard
recognizable formats.
• A road or a speed limit has recently
changed.
This seems to imply tesla is reading signs. I guess they could be cagey and are alluding to old mobileye cars in this description.
2019.16.1.1
May 16, 2019
limit.
determined:
240 km/h).
situations:
snow, fog, etc.).
objects.
changed.
