Um. Reminds me of Dirty Harry, "Ya feelin' lucky, punk?"
From time to time Tesla runs out of the Wall Connectors. Cue people running around like chickens with their heads cut off, followed by a new supply from Tesla and relaxation.
From time to time Tesla changes how much they charge for the thing. Latest was going from $500 to $400 (!).
Finally: It's not just enough to get the blame thing, it's getting it installed that usually ends up with Issues. Now, if you're planning on a Do It Yourself Project, and you have the tools and experience, stop reading this now
There are people who look like perfectly competent electricians, and maybe are, but, with the existence of either scallywags or just somebody making an honest mistake, the result is a Wall Connector that's been improperly installed. There's been cases of screws not tightened down right, neutral where there should be a ground, and so on and so on. The usual way to find out if a mistake has been made is to Plug The Car In and Watch It Charge. That catches 95% of mistakes and, if the electrician is still there, (a) makes it difficult for them to take your money and run and (b) more likely than not to figure out that they got the left-handed whatchamacallet in backwards and to put it in the right way on the spot.
This funny business doesn't happen all the time. But there's been loads of improper install reports on the forums because, well, people are human and make mistakes. A Wall Connector is not a 120 VAC outlet.
So, in prep for the install, it'd be handy to actually
have a Tesla to plug in. And to have verified that that Tesla actually can do L2 charging. (There's the exceedingly rare cases of a Tesla being able to do DC fast charging, but not AC charging, fun.) If you've got a neighbor with a Tesla who's willing to let you use it for the purpose, then you can get your Wall Connector any time and use the neighbor's car for the test. If not, it'd be better to have the car first, check it at a ChargePoint or something, then use it to verify the electrician's work.
For what it's worth, I wasn't thinking along these lines when the SO and I got our M3 back in 2018. But we did have the car and, at the electrician's suggestion, tested the car charging on the spot and it worked. And it's still working just fine, with both a M3 and a MY in the garage.
And I had a co-worker who bought a M3 a few months later. In his case, using the Gen 2 WC, there were instructions in the manual to Not Change Switch Positions When The Breakers Were On. The electrician did that thing and fried the WC's circuit board. So much for reading manuals. Don't know how the electrician escaped with the money, but my co-worker was lucky: At that time, at that place, Tesla replaced the WC under warranty and drop-shipped him a new one, which worked. (Wiring was fine, following instructions are better).
