I tried doing a search but couldn't find the right answer
In superchargers with peak and off peak rates, does the rate change after you start a session...
If you plugged in while on peak rate do you have to unplug to get the offpeak rate or does it automatically adjust...
Same with the other way, if charging off peak does the rate go up at the top of the hour when the rates change..
Thanks
Thanks
