I set the Tesla to 9A, charge for 4-8 hours at a time and do it 1-2 times a week. But I keep mine plugged in even when not in use.
This is FAR less stress on the electrical circuit then someone running window / portable air conditioner or heater for 6-12 hours daily for weeks or months.
If you are running wire to charge an EV (even if it's only 120V) you're not going to be using the same conduit. It's far quicker to just put in new (and quicker is less expensive when it comes to an electrician and his helper's time).Yes. They should always been inspected and replaced with quality components.
Each time I moved I always replace all the outlets in switches and usually do some box cleanup and occasional new wire pulls, which you have to be very careful with, especially with older wire. You can cause more problems pulling new wire if your not careful, especially if you’re leaving old wire in the same conduit. You never know what’s been installed behind the plate, how it’s wired, etc.
Yeah my 1978 house was wired using outlets with the wires just pushed in the back. I had a bathroom circuit fail where the neutral side opened up so to earth ground You could see 120v but nothing would work since no return. Now in the process of replacing all the outlets and using the screws! For charging circuit I bought a commercial quality gfi outlet. My electrician friend says that over time the spring contacts loose their springiness.Using a regular 120v wall plug for continuous 12a EV charging is certain to stress the circuit over time. This is like running a vacuum cleaner or microwave oven for hours on end, every single day.
If you intend to charge this way long-term, at minimum I’d replace the receptacle you intend to use with a high quality commercial/industrial unit and check the connection points of every other outlet on the circuit. If the other receptacles are the cheapo “stab” type with the wires just poked into the back, I’d replace all of them with higher quality units and use the screw-down posts.
There’s no reason to plug and unplug the mobile connector and take it with you every day. Few if any people actually need it. In 110,000 miles and 4 years, I can count the number of times I needed to bring it with me on both hands.
Correct. That's why receptacles have a cycle rating.My electrician friend says that over time the spring contacts loose their springiness.
I heard that plugging in and out regularly wears the thing out and can cause a fire. Or is this specifically for the drier plugins (not the regular prong plugins).
Poe's Law is at work here. I can't tell if this is satire/sarcasm or not.Yes. Totally. It's a known flaw Tesla is keeping from the public.
Tesla did not force Leviton to make crummy cheap-o outlets. They were already doing that. And Tesla's installation documents specify to use either the Hubbell or Cooper ones to get a good solid kind. So no, this obviously isn't Tesla's doing, and they are not "keeping this from the public".
Well I guess that answers that question. I pointed out how it's not Tesla's fault, which would have been agreeing/supporting the idea if it were satire, but @Gasaraki apparently really didn't like me explaining how it is Leviton who makes these crappy outlets, so he marked my post with a "Disagree".Im pretty sure that @Gasaraki 's post is very much satire, but with the way TMC is sometimes I understand 100% why you would say that.
... I pointed out how it's not Tesla's fault, which would have been agreeing/supporting the idea if it were satire, but @Gasaraki apparently really didn't like me explaining how it is Leviton who makes these crappy outlets, so he marked my post with a "Disagree".
