dhrivnak
But the human ear is also logarithmic and rarely does one perceive a difference of less than 2 db.Decibels are logarithmic. So the Volt is much louder than the S, audibly.
to my untrained very poor ears, 3 is just the same S when it comes to noise. Phone quality through bluetooth is awesome.
Ok buddy enlighten me? Numbers?
I bought the RPM product and actually had Mark (the guy in all the videos) install it. He's a total car guy and uses all of his products on his Model 3 and model S cars. I don't notice much noise interference while driving and the product has never popped out of the channel.Anybody try this yet? Wondering if it makes a difference. Obviously RPM claims it does, but would love to hear from actual customers
RPM Tesla
Excellent idea to calibrate the mic using the stereo in the car. Probably the only standard noise maker that everyone taking these measurements has available. Just pick a standard location in the car and a standard volume level with your file & there you go. I think I read that the car will only play mp3s but I'm not sure. Hopefully I'll have my car in the next week or two and I can join in.To everyone measuring sound levels (with their phone or by other device) - have you standardized on a location for the phone/dB meter? That's obviously very important but I haven't seen it mentioned.
Also, if we want to be more scientific about it, it would be good to "calibrate" everyone's meter with the same signal. I suspect there's a decent amount of phone-to-phone microphone response variation. Here's an ogg file (does the Model 3 play ogg files?) of 10 seconds of pink noise. If everyone making measurements put that file on a USB stick and played it at the same volume (and neutral EQ / with enhancement off) settings as everyone else, this reading could be subtracted from the wind noise dB reading and comparisons between different people's measurements would be at least slightly more meaningful.
Appreciate all the research/effort so far!
Ditto!! And my MS has the 21s!When I measured our 3 compared to our S, it was 3db higher on the same roads at the same speeds, around 65-70. Two weeks ago on a weekend trip, we drove about 77 the whole time and the 3 was so loud it was really fatiguing. We had to speak much louder than usual to hear each other clearly and turn up our podcasts and music. I don't think it's mainly wind noise causing the problem. In our S on another trip last week at 77, we could speak at normal levels. The 3 has the 19" sport wheels and our S has the 19" standard slipstream wheels. I got the long range 3 to use it for road trips, but the noise makes our S much more comfortable. It's like the difference between sitting in first class vs right next to the engine.
It will also play FLACs (even 24bit 96kHz ones!). I'm just not sure about ogg.I think I read that the car will only play mp3s but I'm not sure.
It does sound like a lot of the noise folks are reporting could be tire noise.
Bingo! Or at least, that is what is most noisy on my M3. (Never driven an S for comparison, however.) When on the freeway yesterday at ~60, I turned down the radio and the most I heard was the hum of the Conti's. (19" rims).
That is why I went back to my AerosAgreed, tire noise is the main noise issue in the Model 3, not wind. I have the 18" wheels and the noise is not really that bad, but it's definitely louder than my MX with 20" wheels. Has anyone tried to add sound deadening material to the wheel wells? It looks like you could pop off the wheel well lining (there are some fastener clips showing) and stuff some insulation in there.
Then you may want to try the rpmtesla solution of running a rubber type material in the gutter around the roof glass.That is why I went back to my Aeros
I also hear a lot of wind noise where the windshield hits the roof line.
Thank you for this info.Then you may want to try the rpmtesla solution of running a rubber type material in the gutter around the roof glass.
I am not seeing much wind noise in mine. Road noise is equivalent to my earlier S
Pictures please.. or better yet post some videosI got two strips of paint protection film, about 2 in wide and placed them over the glass panel gaps on the roof. Seems to me a 'slicker' alternative to RPMs long tube. The only sound at freeway speeds is the tires on the pavement. On really smooth pavement the car is super quiet. I'm thinking about covering the glass to paint side gaps as well.
